Delete data with Flux Language
Hi All,
I’m trying to delete some data from a bucket with no results.
I’m trying with Flux Language
import "http"
import "json"
http.post(
  url: "http://10.67.61.169/:8086/api/v2/delete?bucket=MyBucket&org=MyOrg",
  headers: {Accept: "application/json", Authorization: "Token TokenFromAPIWEBaPage", "Content-Type": "application/json"},
  data: json.encode(v: {
  "predicate": "_measurement=\"R12_WD\")",
  "start": "2020-06-30T18:00:00Z",
  "stop": "2020-07-03T00:00:00Z"})
This, from the InfluxDB script builder results in
error calling function "post" @4:1-11:2: connectex: The connection could not be established. Persistent rejection of the target computer.
I know there are other methods ( CLI or Curl ) for deleting data but I can’t get them to work.
Any help?
Cheers,
InfluxDB v2.3.0+SNAPSHOT.090f681737
Hello @Cristian_Bertulli,
Are you using an all access token?
I would try the following with the CLI:
influx delete --bucket MyBucket \
  --start '2020-06-30T18:00:00Z' \
  --stop '2020-07-03T00:00:00Z' \
  --predicate '_measurement="R12_WD"'
After setting up your InfluxDB CLI config with
influx config create --config-name <config-name> \
  --host-url https://us-west-2-1.aws.cloud2.influxdata.com \
  --org <your-org> \
  --token <your-auth-token> \
  --active
Make sure you’re using the right config with
influx config ls
The following worked for me:
import "array"
import "http"
import "json"
http.post(
  url: "https://us-west-2-1.aws.cloud2.influxdata.com/api/v2/delete?bucket=test&org=myorg@influxdata.com",
  headers: {Accept: "application/json", Authorization: "Token myAllAccessToken", "Content-Type": "application/json"},
  "predicate": "_measurement=\"meas\")",
  "start": "2021-07-05T00:00:00Z",
  "stop": "2021-07-06T00:00:00Z"})
array.from(rows: [{foo:"foo"}])
|> yield(name: "foo")
Hi @Anaisdg,
Thanks for your reply.
Unfortunately, the Flux script you suggested is not working, the same error pops out :frowning:
Yes, I’m using an all-access token, I’ve even made a new one.
It will be great to use CLI but I simply can’t get it to work.
I’ve downloaded it and followed the instruction from here: Install and use the influx CLI | InfluxDB OSS 2.3 Documentation
But when I open it, instead of opening a CLI interface it simply does nothing.
Cheers,
What version of InfluxDB are you using?
What OS are you running?
A CLI interface won’t automatically pop. For example with macOS you have to type influx in the terminal after installing the InfluxDB CLI in order to use the InfluxDB CLI.
Windows 10 Pro (64bit)
I don’t know how but now CLI is working :thinking: :expressionless:
I tried the delete command but it seems I have difficulties with parsing time :sweat_smile:
influx delete --bucket Test12 --start '2022-06-30T18:00:00.999999999Z07:00' --stop '2022-07-03T00:00:00.999999999Z07:00' --predicate '_measurement="R12_WD"'
Error: start time "'2022-06-30T18:00:00.999999999Z07:00'" cannot be parsed as RFC3339Nano: parsing time "'2022-06-30T18:00:00.999999999Z07:00'" as "2006-01-02T15:04:05.999999999Z07:00": cannot parse "'2022-06-30T18:00:00.999999999Z07:00'" as "2006"
I tried with 2022-06-30T18:00:00Z or 2022-06-30T18:00:00.00Z or 2022-06-30T18:00:00.000Z but the same error message pops up.
Cheers and thanks for the help
@Cristian_Bertulli,
Can you please try copy and pasting:
influx delete --bucket Test12 \
I tried to copy-paste into the Prompt but it takes line per line so it ends up with error
Error: Required flags "start, stop" not set
So I tried to write it manually, but it says Error: unknown command "\\" for "delete"
I must be missing something very simple here, so forgive me for my silly question.
What is the difference between what you wrote
and
influx delete --bucket Test12 --start '2022-06-30T18:00:00Z' --stop '2022-07-03T00:00:00Z' --predicate '_measurement="R12_WD"'
besides the year ( which is 2022, I wrote it wrong the first time ).
Thanks a lot for the help :muscle: and sorry for taking so much time :sweat_smile:
If you copy and past the entire chunk including the back slashes it includes a line continuation. And you shouldn’t get that error. What OS are you using?
Otherwise you can do:
influx delete --bucket Test12  --start '2020-06-30T18:00:00Z' --stop '2020-07-03T00:00:00Z' --predicate '_measurement="R12_WD"'
I’ve tried all the possible DateTime formats but still the same error " Cannot be parsed ad RFC3339Nano "
Cheers and thanks :grinning:
I’m very late finding this thread, but anyone else who comes across it - I believe the answer to the problem here is that you must execute through powershell. If you use a windows CLI it’ll produce the above error. I suspect it has to do with date interpretation in each CLI … but I haven’t bothered to do more than reproduce the problem in standard CLI, and watch it work in powershell.
Cheers.
