RPIs use ARM instruction sets and can be 32 or 64 bit.
Is the Influxdb ARM download,
influxdb-1.8.0_linux_armhf.tar.gz
suitable for all these?
Yes, armhf is the right version. From what I’ve seen, running a 64-bit OS on an RPi is still quite rare (pi 4 - 64-bit OS on Raspberry Pi 4 - Raspberry Pi Stack Exchange)
Thanks for the reply.
I found online os dependant install instructions for InfluxDB and the right version, in my case Buster, was installed. However I am not so certain about the influx_client and that is what I and my code, is struggling with.
from influxdb import InfluxDBClient
Is erroring in my python code with
No module named influxdb
Hello @peterb,
Can you please share the output from the pip install? pip install influxdb Requirement already satisfied: influxdb in ./anaconda3/lib/python3.6/site-packages (5.0.0)? I don’t get any errors:
python
Python 3.6.9 |Anaconda, Inc.| (default, Jul 30 2019, 13:42:17)
[GCC 4.2.1 Compatible Clang 4.0.1 (tags/RELEASE_401/final)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
I’m following the installation instructions as listed here.
However please note that this client isn’t maintained. Please use this client instead.
To write data to v1.x with the latest client please note:
To query to v1.x with the latest client please note:
If you plan to use this new client library with InfluxDB 1.8 or greater, here are some important tips about gathering the required authorization parameters:
For example: a bucket name of telegraf/1week allows you to write the InfluxDB 1.x database named “telegraf” with a retention policy named “1week”. Similarly, telegraf / or telegraf allows you to write to the InfluxDB 1.x database named “telegraf” and the default retention policy (typically autogen ).
username:password
Thanks for your input. I would like to close this thread as I have another in the forum discussing this problem.
https://community.influxdata.com/t/import-influxdbclient-fails-in-python-code/14239/8
However a comment on your last post. The client link goes to a Influxdb 2.0 repository, can that be used with 1.8?
