Here is the deployment.yaml:
apiVersion: extensions/v1beta1
kind: Deployment
metadata:
name: {{ template “chronograf.fullname” . }}
labels:
app: {{ template “chronograf.fullname” . }}
chart: “{{ .Chart.Name }}-{{ .Chart.Version }}”
release: “{{ .Release.Name }}”
heritage: “{{ .Release.Service }}”
spec:
replicas: {{ .Values.service.replicas }}
template:
metadata:
labels:
spec:
containers:
- name: {{ .Chart.Name }}
image: “{{ .Values.image.repository }}:{{ .Values.image.tag }}”
imagePullPolicy: {{ .Values.image.pullPolicy }}
{{- if .Values.oauth.enabled }}
env:
- name: TOKEN_SECRET
valueFrom:
secretKeyRef:
key: token_secret
{{- if .Values.oauth.github.enabled}}
- name: GH_CLIENT_IDx
valueFrom:
secretKeyRef:
key: gh_client_id
- name: GH_CLIENT_SECRET
valueFrom:
secretKeyRef:
key: gh_client_secret
- name: GH_ORGS
valueFrom:
secretKeyRef:
key: gh_orgs
{{- end }}
{{- if .Values.oauth.heroku.enabled}}
- name: HEROKU_CLIENT_ID
valueFrom:
secretKeyRef:
key: he_client_id
- name: HEROKU_CLIENT_SECRET
valueFrom:
secretKeyRef:
key: he_client_secret
- name: HEROKU_ORGS
valueFrom:
secretKeyRef:
key: he_orgs
{{- end }}
{{- if .Values.oauth.google.enabled}}
- name: GOOGLE_CLIENT_ID
valueFrom:
secretKeyRef:
key: go_client_id
- name: GOOGLE_CLIENT_SECRET
valueFrom:
secretKeyRef:
key: go_client_secret
- name: GOOGLE_DOMAINS
valueFrom:
secretKeyRef:
key: go_domains
- name: PUBLIC_URL
valueFrom:
secretKeyRef:
key: go_public_url
{{- end }}
{{- if .Values.oauth.auth0.enabled}}
- name: AUTH0_DOMAIN
valueFrom:
secretKeyRef:
key: auth0_domain
- name: AUTH0_CLIENT_ID
valueFrom:
secretKeyRef:
key: auth0_client_id
- name: AUTH0_CLIENT_SECRET
valueFrom:
secretKeyRef:
key: auth0_client_secret
- name: PUBLIC_URL
valueFrom:
secretKeyRef:
key: auth0_public_url
{{- end }}
{{- end }}
ports:
- containerPort: 8888
livenessProbe:
httpGet:
path: /ping
port: api
readinessProbe:
httpGet:
path: /ping
port: api
volumeMounts:
- name: data
mountPath: /var/lib/chronograf
- name: config
mountPath: /usr/share/chronograf/resources
resources:
{{ toYaml .Values.resources | indent 10 }}
volumes:
- name: config
configMap:
- name: data
{{- if .Values.persistence.enabled }}
persistentVolumeClaim:
claimName: {{ template “chronograf.fullname” . }}
{{ else }}
emptyDir: {}
{{ end }}
Also, here is the configmap.yaml that is referenced in the volumes:
apiVersion: v1
kind: ConfigMap
metadata:
labels:
data:
chronograf.src: |+
“id”: {{ .Values.config.influxdb.id | quote }},
“name”: {{ .Values.config.influxdb.name | quote }},
“username”: {{ .Values.global.influxdb_username | quote }},
“password”: {{ .Values.global.influxdb_password | quote }},
“url”: “https://{{ template “influxdb.fullname” . }}.{{ .Release.Namespace }}:8086”,
“type”: {{ .Values.config.influxdb.type | quote }},
“insecureSkipVerify”: {{ .Values.config.influxdb.insecureSkipVerify }},
“default”: {{ .Values.config.influxdb.default }},
“telegraf”: {{ .Values.config.influxdb.telegraf | quote }},
“organization”: {{ .Values.config.influxdb.organization | quote }}
chronograf.kap: |+
“id”: {{ .Values.config.kapacitor.id | quote }},
“srcID”: {{ .Values.config.kapacitor.srcID | quote }},
“name”: {{ .Values.config.kapacitor.name | quote }},
“url”: “https://{{ template “kapacitor.fullname” . }}.{{ .Release.Namespace }}:9092”,
“active”: {{ .Values.config.kapacitor.active }},
“organization”: {{ .Values.config.kapacitor.organization | quote }}
You can see here from inside the pod, that the files show up in the appropriate location:
/ # ls -al /usr/share/chronograf/resources
total 12
drwxrwxrwx 3 root root 4096 Oct 2 20:17 .
drwxr-xr-x 1 root root 4096 Oct 2 20:17 …
drwxr-xr-x 2 root root 4096 Oct 2 20:17 …2019_10_02_20_17_12.067645013
lrwxrwxrwx 1 root root 31 Oct 2 20:17 …data -> …2019_10_02_20_17_12.067645013
lrwxrwxrwx 1 root root 21 Oct 2 20:17 chronograf.kap -> …data/chronograf.kap
lrwxrwxrwx 1 root root 21 Oct 2 20:17 chronograf.src -> …data/chronograf.src
And the contents are there:
/ # cat /usr/share/chronograf/resources/chronograf.src
“id”: “10000”,
“name”: “Splice Influx”,
“username”: “splice_admin”,
“password”: “********”,
“url”: “https://splice-tick-influxdb.default:8086”,
“type”: “influx”,
“insecureSkipVerify”: true,
“default”: true,
“telegraf”: “telegraf.autogen”,
“organization”: “Default”
