Regards,
I want to calculate power usage on my heat pump using temperature sensor.
Now I can visualize data but cannot calculate right power.
It is easy to determine when pump working. If temp otuput is > 30 pump working. I found way to make step function
SELECT (((abs(mean("temp_input") - 29 ) / (mean("temp_input") - 29) + 1 ) /2)/24) as uptime FROM "sensors" WHERE ("feature" = 'temp1') AND $timeFilter GROUP BY time($__interval) fill(null)
Another way
SELECT mean(“temp_input”)/mean(“temp_input”) FROM “sensors” WHERE (“feature” = ‘temp1’) AND “temp_input”> 30 AND $timeFilter GROUP BY time($__interval) fill(null)
Any idea how to calculate power usage for specific time range.
Thank you
Heat pump power 2,5kW
