Good day
Hope all is well.
I am using Grafana for monitoring a 3phase electrical db. So I am receiving 3 values every 5 sec into the DB.
How can I calculate the total consumption used per month?
Good day
Hope all is well.
Please tell us at least which back-end data store you are using, and what
units the measurements are in (eg: Ampères, Watts, Joules, kWh…).
Antony.
Hi
SO I am using a Shelly 3em to node red to influx to Grafana.
getting it in watts.
So, you have 3 values of power in Watts every 5 seconds going into InfluxDB,
and you want to know the total number of Watts consumed per month?
How about:
select sum(phase1)+sum(phase2)+sum(phase3) from yourtable where
topic=‘whatever’ and $timeFilter
Set “timeFrom” to “1M/M”
Let us know if that works, of if not, in what way the result isn’t correct.
Antony.
Thanks for that
but you are going to need to give me more info. I am abit stupid with building quires
SELECT mean(“power2”) FROM “habbydb2” WHERE $timeFilter GROUP BY time($__interval) fill(null)
building quires
Not stupid - just inexperienced.
Okay, let’s start with that query - what is the problem with it?
Tell us what results it returns, and what result you expected it to return.
Antony.
This query is giving me the latest value.
I need to view al 3phase
power1
power2
power3
together for a period of 1 month.
need to have the actual power used.
So, try “mean(power1),mean(power2),mean(power3) from…”
And set the Absolute Time Range From=now/M and To=now/M
Antony.
