Power use per Day
Hi I am currently collecting SNMP information from a power monitor which is giving me current power usage in KW for our datacenter - what i am looking for is a way to combine this information in to a usage per day.
My current query in Grafana is
SELECT last(“INPUT KW”) FROM “snmp” WHERE (“agent_host” = ‘xx.x.x.xx’) AND $timeFilter GROUP BY time(15s)
my question is how do i combine the collected information in to a bar graph that would show the past x number of days total usage - i have tried (although briefly to edit the query by using “sum” and group by 1day etc but the query provides no data - this leads me to believe i may need to do something on the DB side to be able to visualise the information.
Any help greatly appreciated.
Is last() what you really want? Might mean() not be more meaningful?
Try something like:
SELECT sum(kW) from (SELECT last(“INPUT KW”) as kW FROM “snmp” WHERE
(“agent_host” = ‘xx.x.x.xx’) AND $timeFilter GROUP BY time(15s)) group by time
(1d)
Antony.
Hi, the query ive pasted is a query based on showing me the last point of data received so i can see a movement of power usage throughout a day as servers ramp up/down and crac units cool more etc.
You are right in that “last” isn’t the metric i would be after when collecting a days total -
ive just tried
SELECT sum(kW) from (SELECT last(INPUTKW) as kW FROM snmp WHERE
(agent_host = “10.4.8.19”) AND $timeFilter GROUP BY time(15s)) group by time(1d)
and the result brings in no data points. - there has got to be something somewhere not quite right but i cant put my finger on it
servers ramp up/down and crac units cool more etc. You are right in that
ive just tried
time(1d)
Have you tried the query directly in Influx (rather than Grafana)?
I often find doing a query in the Influx client gives me an insight into what
needs to go into Grafana.
I would start with:
SELECT last(INPUTKW) as kW FROM snmp WHERE (agent_host = “10.4.8.19”) AND
now()-4h GROUP BY time(15s)
Make sure you get a table of results, and that the column is headed “kW”.
Then repeat that with the outer select on it:
(agent_host = “10.4.8.19”) AND time>now()-4h GROUP BY time(15s)) group by
time(1d)
I’d expect a single result for this.
Expand the inner time range:
(agent_host = “10.4.8.19”) AND time>now()-48h GROUP BY time(15s)) group by
time(1d)
That should give two or three data points, I think.
Hope that helps,
Antony.
