Dear everybody,
I’m looking to do something “easy on the paper” but unortunately I don’t suceed after many trials…
I will try to describe it easy.
I have 3 data stored in my database :
- salon (°C) => Average temperature of my house
- jardin (°C)=> Average temperature of my garden
- pompe_a_chaleur (kWh) => Energy consummed by my heating pump by day
I want to calculate the efficiency of my heating system in kWh/°C by doing this calculation :
- HeatingPumpEfficiency = pompe_a_chaleur / abs( salon - jardin)
Below my current query which works :
import "date"
import "experimental"
DAY_STOP = date.truncate(t: now(), unit: 1d)
DAY_START = experimental.addDuration(d: -7d, to: DAY_STOP)
TABLE1 = from(bucket: "home1_raw_data")
|> range(start: DAY_START , stop: DAY_STOP)
|> filter(fn: (r) => r["_measurement"] == "kWh")
|> filter(fn: (r) => r["entity_id"] == "pompe_a_chaleur")
|> filter(fn: (r) => r["_field"] == "value")
|> filter(fn: (r) => r["domain"] == "energie")
|> filter(fn: (r) => r["instance"] == "test")
|> aggregateWindow(every: 1d, fn: spread, createEmpty: false)
|> keep(columns: ["_time", "entity_id", "_value"])
TABLE2 = from(bucket: "home1_raw_data")
|> filter(fn: (r) => r["_measurement"] == "°C")
|> filter(fn: (r) => r["domain"] == "temperature")
|> filter(fn: (r) => r["entity_id"] == "jardin")
|> filter(fn: (r) => r["instance"] == "prod")
|> filter(fn: (r) => r["source"] == "capteur")
|> drop(columns: ["domain", "instance", "source", "_start","_stop", "_field", "_measurement"])
|> aggregateWindow(every: 1d, fn: mean, createEmpty: false)
TABLE3 = from(bucket: "home1_raw_data")
|> filter(fn: (r) => r["entity_id"] == "salon")
UnionTable = union(tables: [TABLE1, TABLE2, TABLE3])
|> sort(columns: ["_time"])
UnionTable
Result of my query :
balaji
#2
Try adding pivot()
followed by map()
as illustrated below:
|> pivot(rowKey:["_time"], columnKey: ["entity_id"], valueColumn: "_value")
|> map(fn: (r) => ({ r with _value: r.pompe_a_chaleur/math.abs(x: (r.salon-r.jardin))}))
Please remember to also import the math package in the beginning - import "math"
Let us know if this works.
Regards
Balaji
Thanks,
I will try it asap for me and keep you informed !
Great, it works like a charm !
Comments :
- I have changed the unit to Wh/°C
My final query :
import "date"
import "math"
DAY_START = experimental.addDuration(d: -14d, to: DAY_STOP)
|> map(fn: (r) => ({ r with delta_temperature: math.abs(x: (r.salon-r.jardin))}))
|> map(fn: (r) => ({ r with efficacite_chauffage: (r.pompe_a_chaleur/math.abs(x: (r.salon-r.jardin)))*1000.0}))
|> keep(columns: ["_time", "efficacite_chauffage", "delta_temperature"])
UnionTable
The result :
