Description:
Certain actions in Monitoring & alerting, while creating new Threshold check lead to fast memory leak, high CPU usage. Then container reboots.
Description:
Details of the setup:
InfluxDB 2.0 version - latest beta
Version 2.0.0
(dd4a6fc)
Telegraf config
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## For failed writes, telegraf will cache metric_buffer_limit metrics for each
## output, and will flush this buffer on a successful write. Oldest metrics
## are dropped first when this buffer fills.
## This buffer only fills when writes fail to output plugin(s).
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Logging configuration:
## Run telegraf with debug log messages.
debug = false
## Run telegraf in quiet mode (error log messages only).
quiet = false
## Specify the log file name. The empty string means to log to stderr.
logfile = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:9999
urls = ["http://some-influxdb-server.xxx:9999"]
## Token for authentication.
token = "$INFLUX_TOKEN"
organization = "some-org"
bucket = "Riga-Telegraf-user-PCs-1d"
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics.
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states.
report_active = false
[[inputs.disk]]
## By default stats will be gathered for all mount points.
## Set mount_points will restrict the stats to only the specified mount points.
# mount_points = ["/"]
## Ignore mount points by filesystem type.
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "overlay", "aufs", "squashfs"]
[[inputs.diskio]]
[[inputs.mem]]
[[inputs.net]]
[[inputs.processes]]
[[inputs.swap]]
[[inputs.system]]
# [[inputs.win_perf_counters]]
# [[inputs.win_perf_counters.object]]
# # Processor usage, alternative to native, reports on a per core.
# ObjectName = "Processor"
# Instances = ["*"]
# Counters = ["% Idle Time", "% Interrupt Time", "% Privileged Time", "% User Time", "% Processor Time"]
# Measurement = "win_cpu"
# #IncludeTotal=false #Set to true to include _Total instance when querying for all (*).
# IncludeTotal=true
Numebr of hosts under Telegraf monitoring: 3
All Telegrafs installed to Win 10 pro.
Container is run with next command:
docker run -dit
–name=influxdb
–restart=unless-stopped
–network=host
-v /influxdb:/root/.influxdbv2
Quay --reporting-disabled
6.2 Refresh page. (you shouldn’t close it)
Change “Schedule Every” from 1h (which is still on page after container restart) to 6h.
CPU will jump but then go to norm
6.3 Switch back “Schedule Every” to 1m.
wait for a minute and then switch to 6h.
Memory will be eaten
Wow, I guess Beta version has Issues. Did same happens for TICK stack 1.x version?
Is anyone going to address these OOM issues? If not, I’ll be moving on to Elasticsearch.
