Hi everyone,
I’ve done a lot of testing with this one Bucket when i noticed there were a lot of strange suggested filter options, strange becouse they did not fit any of the data currently displayed in that bucket.
The contents of this bucket were deleted a buch of times, so maybe that has something to do with that?
Thanks in advance!
How are you ingesting the data into InfluxDB? If Telegraf, can you share your .conf file?
I am using telegraf, here is the config file:
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 1000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "5s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
# debug = false
## Log only error level messages.
# quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
# logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
# logfile = ""
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0d"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "0MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Pick a timezone to use when logging or type 'local' for local time.
## Example: America/Chicago
# log_with_timezone = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = true
[[outputs.influxdb_v2]]
urls = ["http://10.*.*.*:8086"]
token = "$INFLUX_TOKEN"
organization = "SMI"
bucket = "testbucket" # fallback if bucket_tag is missing
bucket_tag = "bucket_tag" # use value of this tag as bucket name
exclude_bucket_tag = true # don't write the bucket_tag as a tag
## Content-Encoding for write request body, can be set to "gzip" to
## compress body or "identity" to apply no encoding.
# content_encoding = "gzip"
## Enable or disable uint support for writing uints influxdb 2.0.
# influx_uint_support = false
[[inputs.mqtt_consumer]]
servers = ["tcp://10.*.*.*:1883"]
topics = ["+/BVL/SPS/LOG/+"]
topic_tag = ""
client_id = "InfluxDB-BVL-Access"
username = "username"
password = "password"
data_format = "json"
name_override = "BVL"
topic = "+/BVL/SPS/LOG/+"
tags = "bucket_tag/_/_/_/Maschinennummer"
