[x509_cert] add authority to telegraf container
We have our own authority to generate our certificates.
We use the telegraf:1.23.4 from docker hub.
Our config is :
[[inputs.x509_cert]]
  sources= ["https://vault.mydomain.tld:443"]
Our results are :
[...] verification="invalid",verification_error="x509: certificate signed by unknown authority"}
We tried to add our authority in /usr/local/share/ca-certificates/ and update with /usr/sbin/update-ca-certificates but still unkown authority.
Any idea ?
EDIT :
On docker container :
$ openssl s_client -servername vault.mydomain.tld-connect vault.mydomain.tld:443
Succed with no error validating certificates
My bad ! I just needed to rename .cer to .crt and all work better now !
