Hello everyone!
I Use Telegraf with http plugin
[[outputs.http]]
url = "https://example.com/test/rest/login"
method = "POST"
tls_ca = "/etc/telegraf/ssl1/cert.pem"
tls_cert = "/etc/telegraf/ssl1/cert.pem"
tls_key = "/etc/telegraf/ssl1/key.pem"
but I get an error
Error writing to outputs.http: Post “https://example.com/test/rest/login”: x509: certificate signed by unknown authority
I call with the same information with CURL Command and the command works correctly
curl -v -H “Content-Type: application/json” --key /etc/telegraf/ssl1/key.pem --cert /etc/telegraf/ssl1/cert.pem -d’{“username”:“username”,“password”:“password”}’ https://example.com/test/rest/login
Also, I call the folowing command for the correctness of the certificate
openssl s_client -connect example.com:443 -CApath /etc/ssl/certs
CONNECTED Verification: OK Verify return code: 0 (ok)
please help me how to solve my problem in telegraf
