Telegraf: monitoring SSL certificate
I need check many SSL certificate.
I use x509 Certificate Input Plugin influxdata/telegraf/tree/master/plugins/inputs/x509_cert
this is the config:
[[inputs.x509_cert]]
  sources = ["https://example.org:443"]
When run telegraf I have this error:
21-06-17T23:36:00Z E! [inputs.x509_cert] could not find file: &{https://example.org:443 false false <nil>}
OS: debian 10
Telegraf 1.19.0
Could you help me, please?
Read the documentation. :smirk:
  sources = ["tcp://example.org:443"]
same error:
2021-06-18T16:21:00Z E! [inputs.x509_cert] could not find file: &{tcp://example.org:443 false false }
I tried the config above and it worked - but it was on a win 10 machine.
Do have connectivity at all? Does ping and curl give a response back?
yes, ping con curl are ok.
Here is the issue:
Ok, my telegraf version was 1.17.3
Maybe go back to the last version 1.18.3
Thanks Franky for help me!
