Installed Packages
Version : 1.23.3
try next settings:
[[inputs.x509_cert]]
sources = [“smtp://192.168.1.14:25”]
insecure_skip_verify = true
error:
[inputs.x509_cert] Error in plugin: cannot get SSL cert ‘smtp://192.168.1.14:25’: unsupported scheme ‘smtp’ in location smtp://192.168.1.14:25
try change to tcp://
error:
[inputs.x509_cert] Error in plugin: cannot get SSL cert ‘tcp://192.168.1.14:25’: tls: first record does not look like a TLS handshake
on the remote host 192.168.1.14:25 Postfix
Any idea?
