To be blunt, I am not sure Clearly the Go cert parser doesn’t like something in those policies. I was curious if you see anything that doesn’t look right either.
Is there a --ignore-ca-cert switch?
The only option that the x509 plugin has is the exclude_root_certs which omits root certs and outputs leaf certs.
[inputs.x509_cert] Error in plugin: cannot get SSL cert ‘https://server:443’: tls: failed to parse certificate from server: x509: invalid certificate policies
I see the first three certs get tested, but the fourth is ignored or nothing in output in regards to the cert. Is it’s placement in the config a contributing factor?
[inputs.x509_cert] Error in plugin: cannot get SSL cert ‘https://server4:443’: tls: failed to parse certificate from server: x509: invalid certificate policies
ok so the fourth is also the one that is returning an error, so as a result there won’t be any metrics about it. Placement should not have anything to do with it in your case. Does that align with what you are seeing?
Yeah the other three are in InfluxDB. No reading for the fourth. Like I said, the fourth cert is from a local Windows CA. Does that have any bearing? Also is there a command line to check what telegraf is looking for?
I would take a step back and go back to the error message. It was complaining about the properties. Do you have any other certs with those same properties that work? Could you create one by hand and try it?
depth=2 CN = SERVERCA03
verify return:1
depth=1 DC = dom, DC = domain, CN = isllc-SERVERCA03-CA-1
verify return:1
depth=0 C = US, ST = STATE, L = City, O = Company, CN = server4
verify return:1
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
64:00:00:05:75:9b:a8:a5:31:6e:8b:66:1a:00:01:00:00:05:75
Signature Algorithm: sha256WithRSAEncryption
Issuer: DC = dom, DC = domain, CN = isllc-SERVERCA03-CA-1
Validity
Not Before: Jun 21 22:55:36 2022 GMT
Not After : Jun 20 22:55:36 2025 GMT
Subject: C = US, ST = STATE, L = City, O = Company, CN = server4
X509v3 extensions:
X509v3 Subject Alternative Name:
DNS:server4, DNS:tserver4, IP Address:x.x.x.x, IP Address:x.x.x.x
X509v3 CRL Distribution Points:
Full Name:
URI:http://pki.server.com/CRLD/domain-SERVERCA03-CA-1(1).crl
X509v3 Key Usage:
Digital Signature, Key Encipherment
1.3.6.1.4.1.311.21.7:
0..&+.....7.....*.......9...k...y...........d...
X509v3 Extended Key Usage:
TLS Web Client Authentication, TLS Web Server Authentication
1.3.6.1.4.1.311.21.10:
0.0
func (s *String) readBase128Int(out *int) bool {
ret := 0
for i := 0; len(*s) > 0; i++ {
if i == 5 {
return false
// Avoid overflowing int on a 32-bit platform.
// We don’t want different behavior based on the architecture.
if ret >= 1<<(31-7) {
return false
