X axis is not readable on my histogram. Maybe I do not see the option for reducing the frequency of that axis. For example Grafana shows the same in more readable and understandable format. X axis in Grafana contains steps by 0.5 from 0 to 9.
Hello @Andrey_Ponomarev,
Oof yah the only thing you could customize is the x domain…but yah you need an axis break. You could put each x domain range in a different dashboard cell if you don’t expect the buckets to shift…
Can you please create a feature request here?
Additionally, do you use the UI a lot? If you’re interested in being part of the early access program for notebooks (the upcoming UI) we’d love to get your feedback. Notebooks Early Access | InfluxData
