In InfluxDB v2, the config file is change. check below, it’s a different from v1.
and I now I configured the env variable.
[root@dele ~]# echo $INFLUXD_CONFIG_PATH
/etc/influxdb/
and I follow the fastnetmon influxdb integration as below:
[root@dele ~]# ls /etc/influxdb/
config.toml
[root@dele ~]# more /etc/influxdb/config.toml
[[graphite]]
enabled = true
bind-address = ":2003"
protocol = "tcp"
consistency-level = "one"
separator = "."
batch-size = 5000 # will flush if this many points get buffered
batch-timeout = "1s" # will flush at least this often even if we haven't hit buffer limit
templates = [
"fastnetmon.hosts.* app.measurement.cidr.direction.function.resource",
"fastnetmon.networks.* app.measurement.cidr.direction.resource",
"fastnetmon.total.* app.measurement.direction.resource"
now I restart influxdb and check opened ports, but do not find :2003:
[root@dele ~]# netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp6 0 0 :::8086 :::* LISTEN
tcp6 0 0 :::22 :::* LISTEN
udp 0 0 0.0.0.0:50001 0.0.0.0:*
raw6 0 0 :::58 :::* 7
