Hi All,
Could you suggest me why same alert is triggering multiple times .
Here is my tick file :
// This Script will trigger alert for Oracle log level ORA-.
var ErrorMessageToBeIgnored1 = ‘This is an example Error message to be ignore for the alert.’
// We can declare ‘n’ number of variables to be ignored while alerting for ORA- level.
var db = ‘server_logs’
var rp = ‘autogen’
var measurement = ‘oracle_logs’
var groupBy = [‘host’, ‘alert’]
var whereFilter = lambda: TRUE
var name = ‘Oracle_ServerLog-Linux-Threshold-LogLevel’
var idVar = name
var message = ‘FTAIM: Oracle Server Level alert reports {{.Level}} with value: {{ index .Fields “value” }} on host: {{index .Tags “host”}}.’
var idTag = ‘alertID’
var levelTag = ‘level’
var messageField = ‘message’
var durationField = ‘duration’
var outputDB = ‘alerting’
var outputRP = ‘autogen’
var outputMeasurement = ‘alerts’
var triggerType = ‘threshold’
var crit = ‘ORA-’
// Below we are implemented that body text of Email, which is adopted by .details() method at trigger in alert node.
var emailbody = ‘’‘{{ if eq .Level “CRITICAL” }}
FT Application Infrastructure Monitoring has detected an issue on a monitored system.
Please open the Dataview Application to diagnose the issue.
Error message: {{ index .Fields “value” }} {{ index .Fields “alertmessage” }}
Host:{{ index .Tags “host” }}
Please take required actions immediately.
This email was automatically sent by FT Application Infrastructure Monitoring.
{{end}} ‘’’
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
// Below we are providing the alias names to adopt in this script.
// Example Inside the HTML Tags at Error message place & Host place.
|eval(lambda: “alert”, lambda: “alertdescription”)
.as(‘value’, ‘alertmessage’)
.keep()
.quiet()
|log()
var trigger = data
// Below we are implementing the DefaultErrorList of messages to be Ignored while alerting.
|where(lambda: !strContains(“alertmessage”, ErrorMessageToBeIgnored1))
|where(lambda: strContains(“value”, crit))
|alert()
// Below .crit() we are declaring ORA- as a CRITICAL to alert.
.crit(lambda: TRUE)
.message(message)
.details(emailbody)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
// .topic(‘database_group’)
.email()
.to(‘SKumarB@ra.rockwell.com’)
.to(‘SS4@ra.rockwell.com’)
|log()
trigger
|eval(lambda: strContains(“value”, crit))
.as(‘value’)
.keep()
.quiet()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag(‘alertName’, name)
.tag(‘triggerType’, triggerType)
