I am a bit puzzled why this TICK script sends every alert twice, what do I miss?
dbrp "telegraf"."autogen"
var cpu_temperature_warn_level = 58
var cpu_temperature_crit_level = 80
var regex_topic = /^OpenCH\/(.*)\/([0-9A-Fa-f]{16})\/PubSystemStats\/(.*)$/
var get_device_type = lambda: regexReplace(regex_topic, "topic", '$1')
var get_device_id = lambda: regexReplace(regex_topic, "topic", '$2')
stream
|from()
.measurement('mqtt_consumer')
.where(lambda: ("topic" =~ regex_topic AND "name" == 'temperature'))
|eval(get_device_type, get_device_id)
.as('device_type', 'device_id')
.keep('value')
.tags('device_type', 'device_id')
|alert()
.id('{{ index .Tags "device_type" }} {{ index .Tags "device_id" }} CPU {{ index .Tags "name" }}')
.message('{{ .Level }} {{ .Time }} {{ .ID }} {{ index .Fields "value" }}{{ index .Tags "units" }}')
.warn(lambda: int("value") > cpu_temperature_warn_level)
.crit(lambda: int("value") > cpu_temperature_crit_level)
.log('/tmp/alerts.log')
.slack()
.channel('#debug')
It’s Kapacitor OSS 1.5.2 (git: HEAD 3086452d00830e01d932838d8c6d1df818648ad3)
running on Raspberry Pi 3B+.
A small piece of the /tmp/alerts.log with 2 alerts repeated twice each - with the same timestamp:
{"id":"RPiGateway ba27ebfffee8c620 CPU temperature","message":"WARNING 2019-06-01 13:47:01.389610437 +0000 UTC RPiGateway ba27ebfffee8c620 CPU temperature 62.8℃","details":"{\u0026#34;Name\u0026#34;:\u0026#34;mqtt_consumer\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;cpu_alert_temperature\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{\u0026#34;device_id\u0026#34;:\u0026#34;ba27ebfffee8c620\u0026#34;,\u0026#34;device_type\u0026#34;:\u0026#34;RPiGateway\u0026#34;,\u0026#34;host\u0026#34;:\u0026#34;rpi-opench-data\u0026#34;,\u0026#34;name\u0026#34;:\u0026#34;temperature\u0026#34;,\u0026#34;topic\u0026#34;:\u0026#34;OpenCH/RPiGateway/ba27ebfffee8c620/PubSystemStats/json\u0026#34;,\u0026#34;units\u0026#34;:\u0026#34;℃\u0026#34;},\u0026#34;ServerInfo\u0026#34;:{\u0026#34;Hostname\u0026#34;:\u0026#34;localhost\u0026#34;,\u0026#34;ClusterID\u0026#34;:\u0026#34;56f71fa5-5272-4305-8e00-7fd8955e4faf\u0026#34;,\u0026#34;ServerID\u0026#34;:\u0026#34;54052fbb-a451-4323-91e2-4159b4f31294\u0026#34;},\u0026#34;ID\u0026#34;:\u0026#34;RPiGateway ba27ebfffee8c620 CPU temperature\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;value\u0026#34;:62.8},\u0026#34;Level\u0026#34;:\u0026#34;WARNING\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2019-06-01T13:47:01.389610437Z\u0026#34;,\u0026#34;Duration\u0026#34;:0,\u0026#34;Message\u0026#34;:\u0026#34;WARNING 2019-06-01 13:47:01.389610437 \u0026#43;0000 UTC RPiGateway ba27ebfffee8c620 CPU temperature 62.8℃\u0026#34;}\n","time":"2019-06-01T13:47:01.389610437Z","duration":0,"level":"WARNING","data":{"series":[{"name":"mqtt_consumer","tags":{"device_id":"ba27ebfffee8c620","device_type":"RPiGateway","host":"rpi-opench-data","name":"temperature","topic":"OpenCH/RPiGateway/ba27ebfffee8c620/PubSystemStats/json","units":"℃"},"columns":["time","value"],"values":[["2019-06-01T13:47:01.389610437Z",62.8]]}]},"previousLevel":"WARNING","recoverable":true}
{"id":"RPiData ba27ebfffe755f19 CPU temperature","message":"OK 2019-06-01 13:45:02.004254415 +0000 UTC RPiData ba27ebfffe755f19 CPU temperature 44.5℃","details":"{\u0026#34;Name\u0026#34;:\u0026#34;mqtt_consumer\u0026#34;,\u0026#34;TaskName\u0026#34;:\u0026#34;cpu_alert_temperature\u0026#34;,\u0026#34;Group\u0026#34;:\u0026#34;nil\u0026#34;,\u0026#34;Tags\u0026#34;:{\u0026#34;device_id\u0026#34;:\u0026#34;ba27ebfffe755f19\u0026#34;,\u0026#34;device_type\u0026#34;:\u0026#34;RPiData\u0026#34;,\u0026#34;host\u0026#34;:\u0026#34;rpi-opench-data\u0026#34;,\u0026#34;name\u0026#34;:\u0026#34;temperature\u0026#34;,\u0026#34;topic\u0026#34;:\u0026#34;OpenCH/RPiData/ba27ebfffe755f19/PubSystemStats/json\u0026#34;,\u0026#34;units\u0026#34;:\u0026#34;℃\u0026#34;},\u0026#34;ServerInfo\u0026#34;:{\u0026#34;Hostname\u0026#34;:\u0026#34;localhost\u0026#34;,\u0026#34;ClusterID\u0026#34;:\u0026#34;56f71fa5-5272-4305-8e00-7fd8955e4faf\u0026#34;,\u0026#34;ServerID\u0026#34;:\u0026#34;54052fbb-a451-4323-91e2-4159b4f31294\u0026#34;},\u0026#34;ID\u0026#34;:\u0026#34;RPiData ba27ebfffe755f19 CPU temperature\u0026#34;,\u0026#34;Fields\u0026#34;:{\u0026#34;value\u0026#34;:44.5},\u0026#34;Level\u0026#34;:\u0026#34;OK\u0026#34;,\u0026#34;Time\u0026#34;:\u0026#34;2019-06-01T13:45:02.004254415Z\u0026#34;,\u0026#34;Duration\u0026#34;:-119385356022,\u0026#34;Message\u0026#34;:\u0026#34;OK 2019-06-01 13:45:02.004254415 \u0026#43;0000 UTC RPiData ba27ebfffe755f19 CPU temperature 44.5℃\u0026#34;}\n","time":"2019-06-01T13:45:02.004254415Z","duration":-119385356022,"level":"OK","data":{"series":[{"name":"mqtt_consumer","tags":{"device_id":"ba27ebfffe755f19","device_type":"RPiData","host":"rpi-opench-data","name":"temperature","topic":"OpenCH/RPiData/ba27ebfffe755f19/PubSystemStats/json","units":"℃"},"columns":["time","value"],"values":[["2019-06-01T13:45:02.004254415Z",44.5]]}]},"previousLevel":"OK","recoverable":true}
