My tick file:
dbrp "xxxxxz"."autogen"
stream
// Select just the cpu measurement from our example database.
|from()
.measurement('stream_periodic_stats__agg')
.where(lambda: "__agg_period" == '5s')
|groupBy('__agg_group_by')
|window()
.period(1m)
.every(5s)
.align()
|alert()
.crit(lambda: int("event__count") < 200)
.message('value for tag {{ index .Tags "component_name" }} field event__count:{{ index .Fields "event__count" }} is < 200')
// Whenever we get an alert write it to a file.
.log('/kapacitor/logs/alerts.log')
|httpOut('dump')
|influxDBOut()
.database('xxxxxxxz')
.measurement('alert_output')
I need to implement this Alerting logic on a global state change: For Every 1 min window interval with 12 periodic outputs(.every(5s)), If a condition is met on 3 out of the 12 periods in that window, set a Global variable ALERT_BAD_STATE if it is not already set to TRUE. If a condition is met on 12 out of the 12 periods in that window, set a Global variable ALERT_BAD_STATE if it is not already set to FALSE.
Alert only set on State change for ALERT_BAD_STATE and only if data is coming in(??). Details:
|window
.period: 1m
.every(5s)
.align()
In 1 min interval(12 periods) from a Start time(? or when Kapacitor started ?),
Trigger Condition:
BAD state: if measured variable (output_fps__count) is present and < 29. if condition is TRUE in 3/12 periods(how ?), global variable ALERT_BAD_STATE set to ON/true.
GOOD state: if measured variable (output_fps__count) is present and >= 30. if condition is TRUE in 12/12 periods, global variable ALERT_BAD_STATE set to OFF/false.
How can I do that as I have to maintain state between each of the 12 intervals of the 1 min window ?
I have to redo this again for the each subsequent 1 min window with 12 intervals of 5 secs each.
TIA,
