Kapacitor 1.3 Windows 10 Getting Started - Problem with Alerts
Hello !
I’ve just begun with Kapacitor, InfluxDB and Telegraf. I’m trying to implement all little tasks presented in the InfluxData Getting Started (see that link: https://docs.influxdata.com/kapacitor/v1/introduction/getting-started/).
Everything is ok until the Trigger Alert from Stream data paragraph. I followed the instructions but I got the following error message:
“. expected: “number”,“string”,“duration”,“identifier”,“TRUE”,“FALSE”,”==“,”(“,”-“,”!"1 in "stream
Here is my command:
kapacitor define cpu_alert -type stream -tick cpu_alert.tick -dbrp kapacitor_example.autogen
Here is my cpu_alert.tick:
stream
|from()
.measurement(‘cpu’)
|alert()
.crit(lambda: “usage_idle” < 70)
.log(‘/tmp/alerts.log’)
Finally here is my kapacitor.conf (following the instructions I found on the website):
httppost =
hostname = “localhost”
data_dir = “C:\Users\Louis\.kapacitor”
skip-config-overrides = false
default-retention-policy = “”
[http]
bind-address = “:9092”
auth-enabled = false
log-enabled = true
write-tracing = false
pprof-enabled = false
https-enabled = false
https-certificate = “/etc/ssl/kapacitor.pem”
shutdown-timeout = “10s”
shared-secret = “”
[replay]
dir = “C:\Users\Louis\.kapacitor\replay”
[storage]
boltdb = “C:\Users\Louis\.kapacitor\kapacitor.db”
[task]
dir = “C:\Users\Louis\.kapacitor\tasks”
snapshot-interval = “1m0s”
[[influxdb]]
enabled = true
name = “default”
default = false
urls = [“http://localhost:8086”]
username = “”
password = “”
ssl-ca = “”
ssl-cert = “”
ssl-key = “”
insecure-skip-verify = false
timeout = “0s”
disable-subscriptions = false
subscription-protocol = “http”
kapacitor-hostname = “”
http-port = 0
udp-bind = “”
udp-buffer = 1000
udp-read-buffer = 0
startup-timeout = “5m0s”
subscriptions-sync-interval = “1m0s”
[influxdb-excluded.subscriptions]
_kapacitor = [“autogen”]
[logging]
file = “STDERR”
level = “DEBUG”
[config-override]
enabled = true
[collectd]
enabled = false
bind-address = “:25826”
database = “collectd”
batch-size = 5000
batch-pending = 10
batch-timeout = “10s”
read-buffer = 0
typesdb = “/usr/share/collectd/types.db”
[opentsdb]
enabled = false
bind-address = “:4242”
database = “opentsdb”
consistency-level = “one”
tls-enabled = false
certificate = “/etc/ssl/influxdb.pem”
batch-size = 1000
batch-pending = 5
batch-timeout = “1s”
log-point-errors = true
[alerta]
enabled = false
url = “”
token = “”
token-prefix = “”
environment = “”
origin = “”
[hipchat]
enabled = false
url = “”
token = “”
room = “”
global = false
state-changes-only = false
[opsgenie]
enabled = false
api-key = “”
url = “https://api.opsgenie.com/v1/json/alert”
recovery_url = “https://api.opsgenie.com/v1/json/alert/note”
global = false
[pagerduty]
enabled = false
url = “https://events.pagerduty.com/generic/2010-04-15/create_event.json”
service-key = “”
global = false
[pushover]
enabled = false
token = “”
user-key = “”
url = “https://api.pushover.net/1/messages.json”
[smtp]
enabled = false
host = “localhost”
port = 25
username = “”
password = “”
no-verify = false
global = false
from = “”
idle-timeout = “30s”
[snmptrap]
enabled = false
addr = “localhost:162”
community = “kapacitor”
retries = 1
[sensu]
enabled = false
addr = “”
source = “Kapacitor”
[slack]
enabled = false
url = “”
channel = “”
username = “kapacitor”
icon-emoji = “”
global = false
ssl-ca = “”
ssl-cert = “”
ssl-key = “”
[talk]
enabled = false
url = “”
author_name = “”
[telegram]
enabled = false
url = “https://api.telegram.org/bot”
token = “”
chat-id = “”
parse-mode = “”
disable-web-page-preview = false
disable-notification = false
global = false
[victorops]
enabled = false
api-key = “”
routing-key = “”
url = “https://alert.victorops.com/integrations/generic/20131114/alert”
global = false
[reporting]
enabled = true
url = “https://usage.influxdata.com”
[stats]
enabled = true
stats-interval = “10s”
database = “_kapacitor”
retention-policy = “autogen”
timing-sample-rate = 0.1
timing-movavg-size = 1000
[udf]
[deadman]
interval = “10s”
threshold = 0.0
id = “{{ .Group }}:NODE_NAME for task ‘{{ .TaskName }}’”
message = “{{ .ID }} is {{ if eq .Level "OK" }}alive{{ else }}dead{{ end }}: {{ index .Fields "emitted" | printf "%0.3f" }} points/INTERVAL.”
global = false
I found the
strange and I removed it but it didn’t change anything.
Thanks for your help!
