Hello everyone,
i’m new to influxdb and the last few days i try to understand how influxdb is working behind the scenes. I think i got a rough understanding about this, but a few things are not clear to me and i didn’t found an answer on the internet.
I’m using influxdb 1.8 and playing around a little bit with backup and restore. In the documentation there is a Note: " Note: backup
ignores WAL files and in-memory cache data.".
As i read so far, influxdb write’s data to the WAL-Files and after a given time or a specific amount of space the data of the WAL-Files is written to TSM-Files.
Does this mean, if i’m running a Backup via “influxd backup”, that all data that is currently stored in the WAL-Files is lost?
Thanks!
Hello @Chris_272,
Good question. The backups start at the most recently written TSM generation file written to disk.
Hello @Anaisdg,
thanks for your answer, but this doesn’t really answer my question. But
also sounds like the data in the WAL-Files is lost. So say i have two databases and each database is short before converting WAL-Files to TSM-Files (let’s say 100MB of Data in WAL-Files for each of these two databases), than this would mean, if i run a backup at that time 200MB of Data will be lost (maybe more when using more databases).
This seems a little bit odd fore someone like me, who is coming out of the “SQL-Server”-World
When i have time, i’m going to test it out and if this is really the case
For everyone who cares, i finally got a little time to test and it looks like, that when you run a backup, that the .wal-Files, are being written to a .tsm-File before the backup runs.
Weird that nobody cares or knows about this, but now i know and i’m happy with it
I copied the folder of influx database folder where wal was also stored and also used the influxd command it worked.
