Hi there,
I just installed InfluxDB 1.81 for gathering data of all my smarthome sensors/functionalities.
For visualising the data I decided to use Grafana. But the web-frontend always suggests a lot manipulating query parameters like mean, fill and so on.
But I wanted to see the “raw” data without all the aggregations and so I was looking for another possibility to visualise the data. So I wanted to use Influxdb UI. But after some reading I realized that I didn’t install the newest Version of InfluxDB and that the version I installed doesn’t have a graphical UI.
I upgraded InfluxDB from 1.81 to 2.4. But still there is no graphical UI. Everytime I try to connect on Port 8086 I get : 404 Page not found.
So I searched the already topics here. Result is that the port is already in use. But it is in use by iobroker. I think that Version 1.81 used this port for server/client communication.
Also I didn’t change the communication settings in iobroker when upgrading to Influxdb V2.
The settings still use V1 commucation with Port 8086.
But it still works.
So what to do? Should I change the port in iobroker? But how does Influx know that data comes on a foreign port?
The upgrade itself was no Problem. data and users were upgraded successfully to V2.
