Not able to access InfluxDB UI in Browser
I am using version 1.6.6. I have also tried version 1.8.6 & version 2.0.6. Since 2.0.6 is not compatible to work with k6, so I opted for v1.8.6. And for both 1.8.6 & 1.6.6, I am having the same problem.
I am unable to access InfluxDB UI in the browser even when the “influxd” command is running properly.
Kindly suggest.
Any help would be deeply appreciated.
If i recall, Influx 1.X doesn’t have a web UI. its was deprecated in favour of Chronograf.
I think Influx 2.X does have a web UI built in, it has most of the components of the TICK stack built in (Visualisation, alerting).
Can we use influxdb+grafana to monitor results derived from k6 in windows.
The reason I am asking this is, I have seen commands available for linux/mac & docker. In the document I could not find the same for windows
