vsFlux | import "join" | invalid import path
I would like to use VSCode Flux extenstion with the latest join function but I have to following error text: invalid import path join.
Join: Join data with Flux | Flux 0.x Documentation
The query runs fine on Chronograf, but hard do develop code with it. The VSCode Flux extension has v1.0.4 released on 22-April, and I can not install the lates extension v.1.0.6 released on 22-Oct.
Any idea how to go on?
Workaround found: Error: invalid import path join flux, but I would like to use the latest join function.
Thank you for your help!
Did you find any solution or workaround?
