My influxdb is 2.3
import "date/boundaries"
error @2:1-2:20: invalid import path boundaries
Who knows what the problem is
My influxdb is 2.3
Hi @Marek-maxs,
I am using v2.3 and just tested this with the following results:
import "date"
- works, no error
gives error @1:1-1:25: invalid import path date/boundaries
Note that this is a little different that what you got.
and finally
import "boundaries"
gives error @1:1-1:20: invalid import path boundaries
The same as what you got.
I have not used this package before, but perhaps import "date"
has the functionality that you are looking for.
Thank you for your reply
import "date"
I have no problem importing date. I want to use a boundaries function. I have tried this method in date, but it should not be used
InfluxDB 2.3 shipped with Flux 0.171.0. The date/boundaries
package was introduced in Flux 0.172.0. Answered here
thank you very much
