I wanted to use influxdb oss monitor dashboard. Link is - Set up 1.x monitoring dashboards | InfluxData Platform Documentation. I downloaded the dashboard but while importing dashboard an error is showing - Failed to import dashboard: Error: Cannot read property ‘data’ of undefined. Can somebody help me here?
Hi there,
What version of InfluxDB and Chronograf are you using?
Influxdb version 2.0 and chronograf i am not using. I am using grafana. There also i tried to import this dashboard but it’s available for version 1.x i think.
Since you are using InfluxDB 2.0, you can use the OSS Monitoring Template which you can install directly from the InfluxDB UI or using the CLI tool
