I’d recommend against this for a few reasons. The “.” notation is used to represent . in InfluxDB. So, if you go down this path, it is likely to be confusing to you – and potentially other users.
Suggest using an _ (underscore)?
INSERT abc_dAvg,signature=test\ 800 name=“ABC800” 1514793600
select * from abc_dAvg
time name signature
1514793600 ABC800 test 800
I would suggest uploading data through HTTP in a bulk rather than with INSERT command of InfluxQL.
HTTP endpoint has no problems accepting measurements with “.”.
I think INSERT statement is confusing “.” with space, because it supports retention policy as optional first parameter.
