I’m having trouble with a query that uses a regex to specify the measurement. In a database with about a dozen measurements, when I run:
SELECT last(value) FROM alerta.autogen./Heart.*/ WHERE time > now() - 7d group by resource
it works as expected. There are two measurements that start with ‘Heart’, and I get a result from each for each value of the tag ‘resource’ and from each of those two measurements.
However, when I try to expand this to cover what I think should be every measurement in the database with:
SELECT last(value) FROM alerta.autogen./.*/ WHERE time > now() - 7d group by resource
I get results from only a single measurement (grouped by resource). This happens to be the alphabetically last measurement in the database, not sure if that is significant.
This is version 1.2.2 using a CLI query. Sorry if I’m doing something obviously wrong.
When I couldn’t get this to work I modified the way alerta sends alerts to InfluxDB to put them all in one measurement with the alert name as a tag (vs. multiple measurements w/each alert name its own measurement). That gave me some other benefits, so I sort of let this go and then deleted the excess data that demonstrated this.
I’ve turned the old method back on, but the issue hasn’t reappeared. I don’t think I have all the cardinality I did the last time, so it isn’t a perfect test (and I was thinking the high cardinality might be the issue since the restricted query worked).
So I don’t know if it was just the measurements I had before and not the new ones, if it was the cardinality, or if I just was confused. I did copy and paste the queries, so I would hope I got it correct, but you never know.
I’ll leave the parallel data flow in place for a while to try to build up some cardinality and post back if I can duplicate it. Thanks for the reply.
It’s certainly much easier to use which is why I switched it. The alerta-contrib InfluxDB plugin uses one measurement per alert name, so I think I’ll submit a pull request to at least give people the option.
