Hello
I was facing a strange issue where InfluxDB time series data looks accurate when queried directly via the CLI or Chronograf but when visualized in Grafana; the timestamps seem off by several hours or even drift inconsistently. ![]()
This behavior is especially noticeable when comparing live data to historic values on the same dashboard.
I am using UTC throughout the stack; so I don’t believe it’s a local browser / user setting. ![]()
Could this be due to Grafana’s handling of timezones / something deeper like InfluxDB’s retention policies misaligning timestamps across shards?
I have checked the tz setting in Grafana, ensured server clocks are in sync & verified the data in InfluxDB is being written with UTC timestamps. Still; the visual drift persists intermittently on some panels. ![]()
Checked Time and timezone queries | InfluxDB OSS v2 Documentation. guide related to this and found it helpful.
As someone still getting a grasp on what is Grafana & how it interprets and displays time series data; I would appreciate guidance on aligning InfluxDB output with Grafana visualization; especially for globally distributed monitoring setups. ![]()
Thank you!! ![]()
