Unable to join data in TICK script
I have below TICK script
// Parameters
var period = 10s
var every = 10s
var tolerance = 10d
// Dataframe
// check - http://192.168.0.126:9092/kapacitor/v1/tasks/voc_stats/step1
// check - http://192.168.0.5:9092/kapacitor/v1/tasks/voc_stats/step1
var hourlyAverage = batch
|query('''SELECT mean(usage_user) AS usage_user FROM "telegraf"."autogen"."cpu"  WHERE cpu = 'cpu-total' ''')
    .period(1h)
    .every(every)
|httpOut('step1')
var weeklyAverage = batch
    .period(7d)
    .every(every)
|httpOut('step2')
var weeklyMinimum = batch
|query('''SELECT min(usage_user) AS usage_user FROM "telegraf"."autogen"."cpu"  WHERE cpu = 'cpu-total' ''')
    .period(7d)
    .every(every)
|httpOut('step3')
var data = hourlyAverage
|join(weeklyAverage, weeklyMinimum)
    .as('hourlyAverage', 'weeklyAverage', 'weeklyMinimum')
    .tolerance(8d)
|httpOut('step4')
I can observer the http ouput from step1,2&3 but step 4 is always outputting null series.
httpOut looks like this
step1 :
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-01-29T21:10:26.908059043Z",0.784185539493217]]}]}
Step2:
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-01-22T22:10:46.908007082Z",3.631224120920862]]}]}
Step3:
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-01-28T00:21:15Z",0.1752190237792004]]}]}
step4:
{"series":[{"name":"cpu"}]}
@rawkode, @katy, @Anaisdg @philb Any comments on this ?
Should step 4 be:
var hourlyAverage | batch
    .tolerance(8d)
|httpOut('step4')
Hi @rawkode,
I just copy paste the script it says
invalid TICKscript: parser: unexpected | line 36 char 19 in "lyAverage | batch". expected: "identifier"
line 36 ishourlyAverage | batch
You’re right, that was sloppy copy-pasting on my part.
var hourlyAverage = join(weeklyAverage, weeklyMinimum)
    .tolerance(8d)
|httpOut('step4')
Wait, are you using TICK or Flux?
Hi @rawkode
I am using TICK script editor from chronograf GUI.
Getting this errorinvalid TICKscript: line 28 char 6: cannot get properties of non pointer value
@rawkode Any possible answer for this ? or Do need any extra information on this ? I am running docker from influxdb sandbox. Tried both./sandbox up and./sandbox up - nightly as well
I have tried almost the same script as this today and it seems not working as well
var every = 15s
var custom_period = 3h
// Dataframe
// check - http://192.168.0.123:9092/kapacitor/v1/tasks/Rule-1-cpu/step1
        .period(1h)
        .every(every)
        .fill('none')
        .align()
    |httpOut('step1')
// Custom hours ago average
var customAverage = batch
        .period(1h)
        .every(every)
        .fill('none')
        .align()
        // Query data from custom time ago
        .offset(custom_period)
    |shift(custom_period)
    |httpOut('step2')
        .period(7d)
        .every(every)
        .fill('none')
        .align()
    |httpOut('step3')
        .period(7d)
        .every(every)
        .fill('none')
        .align()
    |httpOut('step4')
    |join(customAverage, weeklyAverage, weeklyMinimum)
        .as('hourlyAverage', 'customAverage', 'weeklyAverage', 'weeklyMinimum')
        .tolerance(2w)
    |httpOut('step5')
Here i have similar outputs
step 1:
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-02-04T18:51:30Z",5.510724480730352]]}]}
step 2:
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-02-04T18:51:30Z",3.297008825595237]]}]}
step 3:
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-01-28T19:51:45Z",4.021326806086728]]}]}
step 4:
{"series":[{"name":"cpu","columns":["time","usage_user"],"values":[["2019-02-04T07:04:30Z",0.17513134851138412]]}]}
step5:
I have tried plenty of permutation and combination but nothing giving me the result, i really appreciate if can provide me a way around.
Hi @BhanuKiran,
Let me run some tests and I’ll get back to you as soon as I can.
Sorry for the delay :+1:
Hi @BhanuKiran,
This appears to be a way the join handles the batched points, but this can be fixed by utilising last().
var period = 10s
var every = 10s
var tolerance = 10d
        .period(1h)
        .every(every)
    |last('usage_user')
        .as('usage_user')
        .period(7d)
        .every(every)
    |last('usage_user')
        .as('usage_user')
hourlyAverage
    |join(weeklyAverage)
        .as('hourlyAverage', 'weeklyAverage')
        .tolerance(1s)
Thanks for your patience, hope this helps!
Thanks @rawkode . :smiling_face_with_three_hearts:
It’s an amazing work around. I have gone through many post but none of them explained this trick. I am also happy that this also solved my another issue of time stamping. In below example, although join node is succeeded but it has an issue with the time stamp.
// Parameters
var every = 10s
// Dataframe
// check - http://ip/kapacitor/v1/tasks/test/step1
// Past one week average
    |query('''SELECT mean(voc) AS voc_0015BC0036000018 FROM "sensordata"."autogen"."voc"  WHERE eui = '0015BC0036000018' ''')
        .period(7d)
        .every(every)
        .groupBy('eui')
        .align()
    |httpOut('step1')
// Past one week minimum
        .period(7d)
        .every(every)
        .groupBy('eui')
        .align()
    |httpOut('step2')
var data = weeklyAverage
    |join(weeklyMinimum)
        .as('weeklyAverage', 'weeklyMinimum')
        .tolerance(2w)
    |httpOut('step3')
data
	|influxDBOut()
    	.database('telegraf')
        .retentionPolicy('autogen')
        .measurement('cpu_stats')
If see the http output
step#1
{"series":[{"name":"voc","tags":{"eui":"0015BC0036000018"},"columns":["time","voc_0015BC0036000018"],"values":[["2019-01-30T19:54:10Z",107.27860696517413]]}]}
step#2
step#3
{"series":[{"name":"voc","tags":{"eui":"0015BC0036000018"},"columns":["time","weeklyAverage.voc_0015BC0036000018","weeklyMinimum.voc_0015BC0036000018"],"values":[["2019-01-28T00:00:00Z",107.27860696517413,107.27860696517413]]}]}
I observe the time stamp in step 3 its always “2019-01-28T00:00:00Z” in every single execution. Effectively Influxdb out node is overwriting the same data point every single time of its execution.
But now i think its will form time series, rather than over writing the same data point again and again.
Thanks, really appreciated.
I’ve been searching for this solution for weeks. This should really be put on influxdata joinnode page as a sidenote or something. Thank you!
