I am trying to create this logic
(1 hour average - 7 day minimum) > 1.5 * (7 day average - 7 day minimum)
After going through many tutorials , I manages to write some tick script
var hourlyAverage = batch
|query('''SELECT mean(usage_user) AS mean_usage_user FROM "telegraf"."autogen"."cpu" WHERE cpu = 'cpu-total' ''')
.period(1h)
.every(30s)
var weeklyAverage = batch
.period(7d)
.every(30s)
var weeklyMinimum = batch
|query('''SELECT min(usage_user) AS min_usage_user FROM "telegraf"."autogen"."cpu" WHERE cpu = 'cpu-total' ''')
.period(7d)
.every(30s)
var data = hourlyAverage
|join(weeklyAverage, weeklyMinimum)
.as('hourlyAverage', 'weeklyAverage', 'weeklyMinimum')
data
|eval(lambda: "hourlyAverage.mean_usage_user" - "weeklyMinimum.min_usage_user")
.as('hourlydiff')
.keep()
|eval(lambda: "weeklyAverage.mean_usage_user" - "weeklyMinimum.min_usage_user")
.as('weeklydiff')
.keep()
|alert()
.crit(lambda: "hourlydiff" > 1.5 * "weeklydiff")
.message('Turn on alert occured ! ')
|influxDBOut()
.database('telegraf')
.retentionPolicy('autogen')
.measurement('cpu_stats')
.precision('s')
Since no alert history is show. Because of influxDBOut, I tried to explore data using chronograf but in “Measurement & Tags” column i don’t see anything measurement named “cpu_stats” and i also tried “SELECT * FROM cpu_stats” inside database.
