I’m trying to join two batch queries. However, after join the series is empties. Please help be debug this.
TICK script:
Error:
Template:
Type: batch
Status: enabled
Executing: true
Created: 08 Mar 19 06:45 UTC
Modified: 08 Mar 19 08:13 UTC
LastEnabled: 08 Mar 19 08:13 UTC
Databases Retention Policies: [“telegraf”.“two_months”]
TICKscript:
dbrp “telegraf”.“two_months”// The measurement to analyze
var measurement = ‘responsetimes’// The amount of data to window at once
var window = 15mvar series = batch
|query(‘’’
SELECT count(timetaken) as count
FROM “telegraf”.two_months.responsetimes
WHERE “responsecode” != ‘10018’ AND “responsecode” != ‘10097’ AND “responsecode” != ‘10181’ AND “responsecode” != ‘10256’ AND “responsecode” != ‘10285’ AND “merchant” != ‘Sevasys’
.period(window)
.groupBy(time(1m), ‘qcinstance’)
.cron(’*/1 * * * *')
.align()
.fill(0)
|log()
.prefix(‘series’)var counts = batch
|query(‘’’
SELECT count(timetaken) as sum
.period(window)
.groupBy(‘qcinstance’)
.align()
.fill(0)
|log()
.prefix(‘counts’)series
|join(counts)
.on(‘qcinstance’)
.fill(‘null’)
.tolerance(14m)
.as(‘counts’, ‘series’)
|log()
.prefix(‘join’)DOT:
digraph join {
graph [throughput=“0.00 batches/s”];query3 [avg_exec_time_ns=“2.683689867s” batches_queried=“52” errors=“0” points_queried=“52” working_cardinality=“0” ];
query3 → log4 [processed=“52”];log4 [avg_exec_time_ns=“46.864µs” errors=“0” working_cardinality=“0” ];
log4 → join6 [processed=“52”];query1 [avg_exec_time_ns=“0s” batches_queried=“52” errors=“0” points_queried=“780” working_cardinality=“0” ];
query1 → log2 [processed=“52”];log2 [avg_exec_time_ns=“234.01µs” errors=“0” working_cardinality=“0” ];
log2 → join6 [processed=“52”];join6 [avg_exec_time_ns=“6.863µs” errors=“0” working_cardinality=“0” ];
join6 → log7 [processed=“0”];log7 [avg_exec_time_ns=“0s” errors=“0” working_cardinality=“0” ];
The logs:
ts=2019-03-08T08:14:00.674Z lvl=info msg="batch point" service=kapacitor task_master=main task=join node=log4 prefix=counts name=responsetimes group=qcinstan
ce=SCLP-FC tag_qcinstance=SCLP-FC field_sum=11 time=2019-03-08T07:59:00Z
ts=2019-03-08T08:14:01.174Z lvl=info msg="batch point" service=kapacitor task_master=main task=join node=log2 prefix=series name=responsetimes
group=qcinstance=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T07:59:00Z
ts=2019-03-08T08:14:01.174Z lvl=info msg="batch point" service=kapacitor task_master=main task=join node=log2 prefix=series name=responsetimes group=qcinstan
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=4 time=2019-03-08T08:00:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:01:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:02:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:03:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:04:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:05:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:06:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=2 time=2019-03-08T08:07:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=1 time=2019-03-08T08:08:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:09:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=4 time=2019-03-08T08:10:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:11:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:12:00Z
ce=SCLP-FC tag_qcinstance=SCLP-FC field_count=0 time=2019-03-08T08:13:00Z
ts=2019-03-08T08:14:01.174Z lvl=info msg="end batch" service=kapacitor task_master=main task=join node=log2 prefix=series name=responsetimes group=qcinstance
=SCLP-FC tag_qcinstance=SCLP-FC time=2019-03-08T08:13:00Z
Here the series are not joining, even though the tag is matching and I have set a tolerance of 14 minutes
