UI configuration not exposed to the CLI?
Hello. I am very new to Influx so I’m trying to learn how to get started.
I’ve installed influxdb and influx-cli, and then started influxd in macOS which is running fine so far:
influx version
Influx CLI 2.7.3 (git: 8b962c7e75) build_date: 2023-04-28T14:22:49Z
influxd version
InfluxDB 2.7.1 (git: 407fa622e9) build_date: 2023-04-27T19:36:53Z
> brew services G influx
influxdb      started         yjmrs  ~/Library/LaunchAgents/homebrew.mxcl.influxdb.plist
I have already exported an INFLUX_TOKEN
export INFLUX_TOKEN=blablatoken
When I go to the About in the UI at http://localhost:8086/, I can see my user ID and organization ID (yjmrs_org).
However, when I drop commands to the CLI:
influx config list
Active	Name	URL	Org
influx org list -t blablatoken
ID	Name
influx bucket find --org yjmrs_org -t blablatoken
ID	Name	Retention	Shard group duration	Organization ID	Schema Type                          272ms
So it seems the UI settings configured through UI are not exposed to the CLI?
Please let me know any missing information.
Hello @yjmrs,
That’s odd.
You should be able to see your buckets created by the UI.
If you create a bucket with the CLI I don’t expect you to see it in the UI but not this way around.
How did you confirm you successfully created a bucket in the UI?
You might need to restart services first.
