401 Unauthorized: unauthorized access InfluxDB CLI
Hi all,
I have an influxDB installation with UI on windows
Now I’m trying to run CLI commands on the same instance.
So, I downloaded the influx CLI and placed it in the same folder as Influxd.
Next, I followed this guide to create a configuration file by filling in the parameters as follows:
–config-name, I entered the name “login”
–host-url, “http://localhost:8086”
–org the organization, used by my user in the UI
–token, I generated an API token in the “API TOKENS” page setting it as “All Acces”
–active, to make it active
But now whatever command I run the message that is shown is the following.
I’m sure I’m doing something wrong, but I can’t figure out what :confused:
Is there anyone who has been in such a situation or who knows how to help me?
influxDB v2.5.1 (git: 5b6fdbf05d) build_date: 2022-11-02T18:06:29Z
influx CLI v2.5.0 (git: 3285a03) build_date: 2022-11-01T16:32:06Z
I think im a “me too” … starting to really regret moving to v2
up to be more visible
you need admin token given when you installed it.
generated tokens do not work with CLI.
Is there any way to retrieve the admin token?
Hi everyone,
I unlocked my situation with this solution
Instead of logging in with a token I used the credentials I usually use in the GUI.
I know it’s not really a solution, but it worked out for me.
i had to reinstall (make a backup of data via files before) and now i backup all my token everyday via CLI
How to login with the the influx 2 command line? The document is confusing, now just figured it out
  1. create a CLI config
influxdb@develop ~ % influx config create \
  -n config-name \
  -u http://localhost:8086 \
  -p USERNAME:PASSWORD \
  -o MyOrganization
  1. Now use the CLI
influxdb@develop ~ % influx user list
ID			Name
0b0b8f90c305e000	datahub
Here is the easier solution as I was experiencing the same 401 error when invoking “influx” on the CLI, I found a better way to change the Token value. The “influx” cmd is tied to the original token as mentioned above, but if you created a new operator || all-access token or deleted the original token, here is the approach to fix it.
If you are running Docker,
  • access your influx container > $sudo docker exec -it CONTAINERID /bin/bash
  • you are now root in your container
  • check if you have nano installed or some editor, if not $apt-get update && apt-get nano
  • $cd /etc/influxdb2
  • this is where you will find the influxdb config file called “influx-configs”
  • now, $influx auth list
  • this will reveal the Token for all the respective users, find the User who has an Operator || All-Access Token, and copy it (I did it with an Operator Token, I think All-Access should work too, as long as you use the -organization flag value that All Access token has access to)
  • then $nano influx-configs, make sure you are in the directory of /etc/influxdb2, if not add path to the nano command
  • you will see the original token in the token key/value pair in the influx-configs file
  • shift+ins to paste the copied Operator token, and remove the original Token value, save file
  • invoke some $influx command, and you should not see the 401 error anymore
This removes the need to reinstall or spin up a new Docker container for influx
p/s: if you are not using Docker, just locate go directly to /etc/influxdb2 on your machine or vm with the same steps
Hope this helps!
