I am first time user, i have got influxd process running and the web console working however I am unable to use the CLI…
Please help…
Amy help is appreciated…
Thanks in advance
I have tried the following steps :
*#### [Using the influx CLI after setting up InfluxDB through the UI]
To use the [ influx CLI] after setting up InfluxDB through the UI, use one of the following methods to provide your [authentication token] to the CLI:
1. Pass your token to the influx CLI using the -t or --token flag.
2. Set the INFLUX_TOKEN environment variable using your token.
3. Store your token in ~/.influxdbv2/credentials . The content of the credentials file should be only your token
However I am still unable to connect to CLI
I see the message :
[See ‘influx -h’ for help]
