Firstly I’m quite new to the InfluxDB ecosystem so apologies if I’ve done something stupid…
I’m struggerling to query my influxDB via the CLI. Using the python API I can run queries fine, but if I type the following into the command line
influx query 'from(bucket:"HARW") |> range(start:-60m)' --org UoB -t <token>
it returns “Access is denied”. However if for example I run
influx server-config -t <the same token>
a result is returned. (If I provide server-conif with an erronous token it returns a 401 error).
Therefore I believe the token I am using is correct, however I still get “access denied” when trying to run a query from the CLI. What am I doing wrong? Cheers in advance for your help.
Fintan
