TTNv3 nad Telegraf using MQTT
I have two configs with separate credentials set up to intake MQTT from TTN and Put them into two separate buckets. Im seeing data from both configs going into both buckets. is there any way to debug this?
Hello @Derek_Tuando,
Welcome!
Whats the problem? Data isn’t separating/splitting to two buckets?
Can you please share your config?
Do you have multiple outputs in your config?
Youll want to use tagpass or tagdrop to route data. Something like:
# Input for data source 1
[[inputs.cpu]]
  ## Add a distinguishing tag
  [inputs.cpu.tags]
    data_source = "source_1"
# Input for data source 2
[[inputs.mqtt_consumer]]
  servers = ["tcp://localhost:1883"]
  topics = ["sensors/temperature"]
  data_format = "json"
  [inputs.mqtt_consumer.tags]
    data_source = "source_2"
# Output for the first bucket
[[outputs.influxdb_v2]]
  urls = ["http://localhost:8086"]
  token = "your_first_token"
  organization = "your_org"
  bucket = "bucket_one"
  ## Only pass data where the data_source tag matches "source_1"
  [outputs.influxdb_v2.tagpass]
    data_source = ["source_1"]
# Output for the second bucket
  token = "your_second_token"
  bucket = "bucket_two"
  ## Only pass data where the data_source tag matches "source_2"
    data_source = ["source_2"]
Or something like
[[inputs.cpu]]
  ## No need to add any tags here
  ## Drop data from the second data source
  [outputs.influxdb_v2.tagdrop]
    mqtt_topic = ["sensors/temperature"]  # Drop data from the MQTT source
  ## Drop data from the first data source (e.g., CPU metrics)
    cpu = ["*"]  # Drop all CPU metrics
I hope this helps!
Yes I have two configs in telegraf.d folder…
CONFIG #1:
  servers = ["mqtts://:example.com:8883"]
  topics = ["v3/APPLICATION_ID/devices/+/up"]
  client_id = "CLIENT 1"
  username = "APPLICATION ID_1"
  password = "API_KEY"
  token = "API_TOKEN"
  organization = "ORG NAME"
CONFIG #2:
servers = [“mqtts://:example.com:8883”]
topics = [“v3/APPLICATION_ID_2/devices/+/up”]
client_id = “CLIENT 2”
username = “APPLICATION ID_2”
password = “API_KEY_2”
data_format = “json”
urls = [“http://localhost:8086"]
token = “API_TOKEN_2”
organization = “ORG NAME”
bucket = “bucket_two”
They both end up in each others buckets.
