I am using Telegraf to transport data from a instance of “THE THINGS STACK to Cloud” to “Influx Cloud 2.0", the The Telegraf is running on a small Debian-10-buster VM instance in Google Cloud. I am using the MQTT Integration in THE THINGS STACK, and streaming data from one end device with two active sensors. The end device ein question can have more than two sensors. I am “storing” the Telegraf config.file in Influx Cloud 2.0: The parts of the Telegraf MQTT config.file looks like this:
[[inputs.mqtt_consumer]]
## Broker URLs for the MQTT server or cluster. To connect to multiple [[inputs.mqtt_consumer]]
## clusters or standalone servers, use a separate plugin instance.
## example: servers = ["tcp://localhost:1883"]
## servers = ["ssl://localhost:1883"]
## servers = ["ws://localhost:1883"]
servers = ["tcp://eu1.cloud.thethings.industries:1883"]
## Topics that will be subscribed to.
topics = ["v3/red001@bluebeam/devices/eui-24e124445d083682/up"]
## The message topic will be stored in a tag specified by this value. If set
## to the empty string no topic tag will be created.
topic_tag = "only2002"
## QoS policy for messages
## 0 = at most once
## 1 = at least once
## 2 = exactly once
## When using a QoS of 1 or 2, you should enable persistent_session to allow
## resuming unacknowledged messages.
qos = 0
## Connection timeout for initial connection in seconds
connection_timeout = "30s"
## Maximum messages to read from the broker that have not been written by an
## output. For best throughput set based on the number of metrics within
## each message and the size of the output's metric_batch_size.
## For example, if each message from the queue contains 10 metrics and the
## output metric_batch_size is 1000, setting this to 100 will ensure that a
## full batch is collected and the write is triggered immediately without
## waiting until the next flush_interval.
# max_undelivered_messages = 1000
## Persistent session disables clearing of the client session on connection.
## In order for this option to work you must also set client_id to identify
## the client. To receive messages that arrived while the client is offline,
## also set the qos option to 1 or 2 and don't forget to also set the QoS when
## publishing.
# persistent_session = false
## If unset, a random client ID will be generated.
# client_id = ""
## Username and password to connect MQTT server.
username = "USER"
password = "PASSWORD"
## Optional TLS Config
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
## Data format to consume.
## more about them here:
data_format = "json"
## Enable extracting tag values from MQTT topics
## _ denotes an ignored entry in the topic path
## Value supported is int, float, unit
# [[inputs.mqtt_consumer.topic.types]]
# key = type
## 0 = at most once
## 2 = exactly once
qos = 0
## publishing.
# client_id = ""
username = "USER"
The data from the device defined under Topics ( topics = [“v3/red001@bluebeam/devices/eui-24e124445d083682/up”]), is streaming data to the Influx 2.0 instance.
However I want to parse out only the relevant signals from the message, which is:
“pt100_1”: 20.1,
“pt100_2": 19.4
.The json file from the relevant device in THE THINGS STACK looks like this:
"name": "as.up.data.forward",
"time": "2023-09-07T18:22:39.714926502Z",
"identifiers": [
"device_ids": {
"device_id": "eui-24e124445d083682",
"application_ids": {
"application_id": "red001"
"dev_eui": "24E124445D083682",
"join_eui": "24E124C0002A0001",
"dev_addr": "2608D24F"
"data": {
"@type": "type.googleapis.com/ttn.lorawan.v3.ApplicationUp",
"end_device_ids": {
"correlation_ids": [
"as:up:01H9RE3J2XFC1FYKBCMZCZK6YY",
"gs:conn:01H8XY3ATBBX3ZG68MPW3RDETS",
"gs:up:host:01H8XY3ATHG3F50W0BA9HTKXKZ",
"gs:uplink:01H9RE3HWBYA7W5F40M09N5RB7",
"ns:uplink:01H9RE3HWCVKTM596ATEECP4K9",
"rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01H9RE3HWCG2V0Y8NJRJ0VSNS4",
"rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01H9RE3J2WZHXW52CW0R4Q0WY6"
"received_at": "2023-09-07T18:22:39.709109152Z",
"uplink_message": {
"session_key_id": "AYgMSk4JwCpe2+phmK+1aw==",
"f_port": 85,
"f_cnt": 176280,
"frm_payload": "AwAABAAABQAABgAABwEACAEACWfJAApnwgA=",
"decoded_payload": {
"gpio_in_1": "off",
"gpio_in_2": "off",
"gpio_in_3": "off",
"gpio_in_4": "off",
"gpio_out_1": "off",
"gpio_out_2": "off",
"pt100_1": 20.1,
"pt100_2": 19.4
"rx_metadata": [
"gateway_ids": {
"gateway_id": "eui-647fdafffe01549f",
"eui": "647FDAFFFE01549F"
"time": "2023-09-07T18:22:39.391Z",
"timestamp": 3709817516,
"rssi": -108,
"channel_rssi": -108,
"snr": 1.5,
"uplink_token": "CiIKIAoUZXVpLTY0N2ZkYWZmZmUwMTU0OWYSCGR/2v/+AVSfEKyl/egNGgwI76nopwYQtaGW7gEg4N/rkvz+ygEqDAjvqeinBhDA37i6AQ==",
"channel_index": 6,
"gps_time": "2023-09-07T18:22:39.391Z",
"received_at": "2023-09-07T18:22:39.409261810Z"
"settings": {
"data_rate": {
"lora": {
"bandwidth": 125000,
"spreading_factor": 7,
"coding_rate": "4/5"
"frequency": "867700000",
"received_at": "2023-09-07T18:22:39.500501394Z",
"consumed_airtime": "0.082176s",
"network_ids": {
"net_id": "000013",
"tenant_id": "bluebeam",
"cluster_id": "eu1",
"cluster_address": "eu1.cloud.thethings.industries",
"tenant_address": "bluebeam.eu1.cloud.thethings.industries"
"origin": "ip-10-23-6-94.eu-west-1.compute.internal",
"context": {
"tenant-id": "CghibHVlYmVhbQ=="
"visibility": {
"rights": [
"RIGHT_APPLICATION_TRAFFIC_READ"
"unique_id": "01H9RE3J32D2KCS6N1TZC13KVF"
I have tried several time using the Telegraf json_v2 parser without any luck. Anybody that can support me ? (edited)
