Beginner question: MQTT > Transform > Influx with TICK stack?
Hi there,
Quick question - I have an existing system that collects sensor data, it looks like this:
Sensor > MQTT > Processor > Postgres
I now want to hook in the TICK stack by connecting it to the MQTT as a subscriber in parallel.
The problem is that the sensor data is basically a json map with various sensor values.
Those are persisted in Postgres as JSONB fields.
This means that a single entry contains multiple sensor readings, e.g. {temp: 50.0, humidity: 30,…} etc
The content varies per sensor.
This probably means - if I’m correct - that I need to transform/dissect the message content before persisting to Influx - how would I do that?
Thanks a lot,
Christoph
Hi @Christoph,
It’s actually a lot easier than you think. I was, like you, over-thinking the whole thing the first time I tried to set up an Influx/MQTT connection. The way to do it is Sensor–>MQTT–>Telegraf–>InfluxDB.
I wrote a blog post about doing this with TheThingsNetwork a month or so ago which might be helpful:Enabling The Things Network for InfluxDB | InfluxData But essentially, all you need to do is configure the Telegraf HQTT plugin:
[[inputs.mqtt_consumer]]
servers = ["tcp://your.mqttserver.com:1883"]
qos = 0
connection_timeout = "30s"
topics = [ "+/devices/+/up" ]
client_id = ""
username = “username"
password = “password"
data_format = "json"
And let Telegraf do the rest. It will automatically pull out and numeric or boolean values and insert them into InfluxDB for you.
Hope that helps!
dg
Thanks a lot @davidgs, I’ll try that.
Just out of curiosity, is there a possibility to use is it as a transformation component between two MQTT queues as well? Or parts of the TICK stack?
I guess it’s possible. I also use Kapacitor with the MQTT output configured so I can write data from Kapacitor to an MQTT broker, so I guess it would be possible to read from a broker, use Kapacitor to transform the data, and then write it back to an MQTT broker as well.
Interesting idea.
dg
