Influxdb_v2 Output to different buckets doesn't work
Hello !
We are trying to output our incoming data to different buckets using tagpass but it doesn’t seem to work. Everything is working inside containers. A Telegraf container is fetching data from a Mosquitto container and tries to send it to the influx (version 2.1.1) container.
We want to send:
input 1 → bucket 1
input 2 → bucket 2
input 3 → bucket 3
How can we get it to work? Do we need a default bucket?
The code:
[agent]
 interval = "20ms"
 round_interval = true
 precision = "rfc3339"
#input 1 Y
[[inputs.mqtt_consumer]]
  servers = ["tcp://e_mqtt:1883"]
  topics = [
  "Y/Schlafzimmer/power/SENSOR",
  [inputs.mqtt_consumer.tags]
    tag = "Y"
  data_format = "json"
#input 2 X
  topics = [
  "X/001/pulse/RESULT",
  "X/002/pulse/RESULT",
  "X/003/pulse/RESULT",
  "X/004/pulse/RESULT",
  "X/005/pulse/RESULT",
  "X/006/pulse/RESULT",
  "X/007/pulse/RESULT",
  "X/008/pulse/RESULT",
  "X/009/pulse/RESULT",
  "X/010/pulse/RESULT",
  "X/011/pulse/RESULT",
  "X/012/pulse/RESULT",
  "X/013/pulse/RESULT",
  "X/014/pulse/RESULT",
  "X/015/pulse/RESULT",
        tag = "X"
#input 3 Z
  topics = [
  "PowerMeter/001/power/SENSOR",
  "PowerMeter/002/power/SENSOR",
        tag = "Z"
#output für 1 Y
[[outputs.influxdb_v2]]
  urls = ["http://e_influxdb:8086"]
  token = "ULw91qCCOyBrVqwWyNdmy8ckzmJhjbrZMhgf57XmXp4elkFsf-atwpQ=="
  organization = "my-org"
  bucket = "Ybucket"
  [outputs.influxdb_v2.tagpass]
    tag = ["Y"]
#output für 2 X
  bucket = "Xbucket"
  tagexclude =["tag"]
    tag = ["X"]
#output für 3 Z
  bucket = "Zbucket"
  tagexclude =["tag"]
    tag = ["Z"]
Thank you!
I would use namepass for the metric filtering:
https://docs.influxdata.com/telegraf/v1/configuration/
Here is a simple example:
Telegraf...specify influxdb database per mqtt input? - #2 by Franky1
There is a better way to do that, use the bucket_tag option of the InflxDB2 output (docs here)
it allows you to specify the “routing” by using a tag value
Here is a sample using your current config
  topics = [
    destination = "Ybucket"
  topics = [
       destination = "Zbucket"
  bucket_tag = "destination"
  ## If true, the bucket tag will not be added to the metric.
  exclude_bucket_tag = true
Thank you!!
Everything is working out now! Thanks a lot!
