Hi, in my Telegraf config I’m using the bucket_tag to get the bucket name from the input, but it also includes the bucket tag in the output (pointless data, because it’s already in the bucket…). I tried using tagexclude in the output, but then it ignored the bucket tag completely and didn’t know where to write the data (404 error). Any ideas on how to remove redundant tags from the output when those tags are required to route data from the input?
In the example config below, I want to route data from the mqtt consumer input to the influxdb2 output for organization “test-customer-1” and bucket “somebucket” when an mqtt message with the topic “test/test-customer-1/somedata” is received. If I remove the tagexclude setting from the output everything works ok, but it stores the redundant bucket and org tags. How do I route data from mqtt consumer to organization “test-customer-1” and bucket “somebucket” without storing the tags “bucket” or “org”?
[[outputs.influxdb_v2]]
urls = ["http://influxdb2"]
token = "xxxx"
organization = "test-customer-1"
tagexclude = ["bucket","org"]
bucket_tag = "bucket"
[outputs.influxdb_v2.tagpass]
org = ["test-customer-1"]
[[inputs.mqtt_consumer]]
servers = ["tcp://host.docker.internal:1883"]
topics = [
"test/+/somedata"
topic_tag = ""
qos = 1
max_undelivered_messages = 10000
persistent_session = true
client_id = "telegraf"
data_format = "json_v2"
[inputs.mqtt_consumer.tags]
bucket = "somebucket"
topic = "+/+/+"
tags = "_/org/_"
