How can I tag all data coming from particular (UDP) inputs.socket_listener? I have two sockets which receive data with identical structure and I want to distinguish them, for example redirecting to different buckets on InfluxDB 2.0.
I want to use this option in [[outputs.influxdb_v2]]
: bucket_tag = ""
it’s as simple as the following example, which I stole from the examples docs
[[inputs.cpu]]
percpu = false
totalcpu = true
[inputs.cpu.tags]
tag1 = "foo"
tag2 = "bar"
This will create 2 tags with the defined values.
You can create your tag (ie: destBucket), with different, static values and use them to route the data to a specific bucket.
Hi Giovanni, thanks for your tip. I’m providing full example which I managed to get working based on it for future reference.
# # Configuration for sending metrics to InfluxDB
urls = ["http://127.0.0.1:8086"]
token = "LALA=="
organization = "ORG"
bucket_tag = "bucket4itz"
exclude_bucket_tag = true
# # collectd
[[inputs.socket_listener]]
service_address = "udp4://:25826"
data_format = "collectd"
content_encoding = "identity"
## Authentication file for cryptographic security levels
collectd_auth_file = "/etc/collectd/passwd"
## One of none (default), sign, or encrypt
collectd_security_level = "encrypt"
## Path of to TypesDB specifications
collectd_typesdb = ["/usr/share/collectd/types.db"]
collectd_parse_multivalue = "join"
[inputs.socket_listener.tags]
bucket4itz = "collectd"
