Trigger alert only between 2 date/time range
Dear All,
I saw some posts mon-fri 8am-9pm, tested with stream and it work fine but this is basic.
  1. Alert triger between 2 date/time range
    Adding this in where, work fine
    hour(“time”) >= 8 AND hour(“time”) <= 17 weekday(“time”) >=1 and weekday("time) <=5
But what we need its to trigger alert only between mon 1:30am to fri 23:35pm when application run basically, similar as ITRS time rule.
Basically something like below
(Weekday(“time”)>=1 and hour(“time”)>=1 and minute(“time”)>=30) and (weekday(“time”) <=5 and hour(“time”) <= 23 and minute(“time”) <= 35)
Your expertise and feedback on how to achieve above.
  1. Or as workaround using slideload
I tried as below even maintenance set to true on yml file and can see true in the log, alert is still triggered which should not be the case.
|sideload()
.source(‘file:///usr/kapacitor/scheduled-maintenance’)
.order(‘hosts/{{.host}}/{{.pattern}}.yml’)
.field(‘maintenance’, FALSE)
pattern1.yml
maintenance: true
stream
|alert()
.crit(lambda: !“maintenance” AND “value” > 80)
.warn(lambda: !“maintenance” AND “value” > 70)
I assume you mean “between 01:30 and 23:35 on each of five days a week” and not
“starting at 01:30 on Monday and finishing at 23:35 on Friday”.
Let’s just break that down - the bracketing makes no difference since every
operator is AND.
weekday must be >=1
weekday must be <=5
hour must be >=1
hour must be <=23
minute must be >=30
minute must be <=35
So, that entire expression will be TRUE on Mondays to Fridays between the
times:
01:30 - 01:35
02:30 - 02:35
03:30 - 03:35 etc…
So, I think what you really want is:
weekday(time)>0 and weekday(time)<6 and
( (hour(time)=0 and minute(time)>29)
or (hour(time)>0 and hour(time)<23)
or (hour(time)=23 and minute(time)<36) )
Regards,
Antony.
Hi Pooh
I need to handle 2 situations
Weekly process as below.
“starting at 01:30 on Monday and finishing at 23:35 on Friday, thats a weekly process running.
Daily one as well
between 06:30 mon to fri 23:35 on each of five days a week”
Or even 06:30 mon to tues 04:00
Hi Pooh
Oh, okay.
( (weekday(time)=1 and hour(time)=1 and minute(time)>29) or
(weekday(time)=1 and hour(time)>1) or
(weekday(time)>1 and weekday(time)<5) or
(weekday(time)=5 and hour(time)<23) or
(weekday(time)=5 and hour(time)=23 and minute(time)<36) )
Daily one as well
Use the example I already gave - change the hour tests from 0 to 5.
( (weekday(time)=1 and hour(time)=6 and minute(time)>29) or
(weekday(time)=1 and hour(time)>6) or
(weekday(time)=2 and hour(time)<4) or
(weekday(time)=2 and hour(time)=4 and minute(time)=0) )
Regards,
Antony.
Thank you Antony for prompt reply. Have a good weekend and enjoy Fathers day.
I will try your recommendation first thing on Monday.
Keep you posted.
Cheers,
Martial
