Only send alert if later than and earlier than
Hi
I set up an alert using the Chronograph UI, but I only want to send it between 5PM and 10PM. I understand this is not possible with the UI, but how can I achieve it with the Tickscript? This is what Chronograph automatically created. Where do I have to define the times? In the where filter?
var db = 'DBNAME'
var rp = 'autogen'
var measurement = 'device_frmpayload_data_co2_ppm'
var groupBy = ['device_name']
var whereFilter = lambda: ("dev_eui" != 'SERIAL' OR "dev_eui" != 'SERIAL' OR "dev_eui" != 'SERIAL')
var name = 'ppm > 800'
var idVar = name + '-{{.Group}}'
var message = 'Alert {{ index .Tags "device_name" }} - CO2 is {{.Level}}'
var idTag = 'alertID'
var levelTag = 'level'
var messageField = 'message'
var outputDB = 'chronograf'
var outputRP = 'autogen'
var outputMeasurement = 'alerts'
var triggerType = 'threshold'
var details = 'HTML data'
var crit = 800
var data = stream
|from()
    .database(db)
    .retentionPolicy(rp)
    .measurement(measurement)
    .groupBy(groupBy)
    .where(whereFilter)
|eval(lambda: "value")
    .as('value')
var trigger = data
|alert()
    .crit(lambda: "value" > crit)
    .message(message)
    .id(idVar)
    .idTag(idTag)
    .levelTag(levelTag)
    .messageField(messageField)
    .durationField(durationField)
    .details(details)
    .email()
    .to('EMAIL')
trigger
|eval(lambda: float("value"))
    .as('value')
    .keep()
|influxDBOut()
    .create()
    .database(outputDB)
    .retentionPolicy(outputRP)
    .tag('alertName', name)
trigger
|httpOut('output')
I left out some personal details.
Thanks!
Regards,
Bert
Hello, you can do this with the alert node in Kapacitor.
There is an example in the deadman section of this link Alert Node
I think if you update this line
to the following, you should get the result you want
.crit(lambda: "value" > crit AND hour("time") >= 8 AND hour("time") <= 17)
You just need to adjust the time values to suit your needs.
Hope that helps.
Thanks for your update.
I tested this with
.crit(lambda: "value" > crit AND hour("time") >= 14 AND hour("time") <= 15)
even changed it to
.crit(lambda: "value" > crit AND hour("time") >= 14 AND hour("time") < 15)
But after 15h I still receive alerts.
I think only the “OK” value - normally sent after the value is normal again are sent after 15h
Solved it by sending the messages to a topic and only match level = CRITICAL
sorry for the delay, I haven’t been on as much. glad you got it sorted :slight_smile:
have you tried a similar lambda expression with the time filter in the .critReset() or the .info() properties of alert ?
I use this code snippit to alert based on different thresholds for different times of day. So I can have different ok,warn,crit thresholds for standard times and exception times. This means I can tune the alerts per time of day.
Starttime_of_standard_alerting and endtime_of_standard_alerting are integer values representing hours eg. 9 and 17 to alert during the day.
|alert()
    .crit(lambda: ("value" >= standard_critical_threshold AND (hour("time") >= starttime_of_standard_alerting AND hour("time") < endtime_of_standard_alerting)) OR
        ("value" >= exception_critical_threshold AND (hour("time") < starttime_of_standard_alerting OR hour("time") >= endtime_of_standard_alerting)))
    .warn(lambda: ("value" >= standard_warning_threshold AND (hour("time") >= starttime_of_standard_alerting AND hour("time") < endtime_of_standard_alerting)) OR
        ("value" >= exception_warning_threshold AND (hour("time") < starttime_of_standard_alerting OR hour("time") >= endtime_of_standard_alerting)))
    .warnReset(lambda: ("value" < standard_warning_threshold AND (hour("time") >= starttime_of_standard_alerting AND hour("time") < endtime_of_standard_alerting)) OR
        ("value" < exception_warning_threshold AND (hour("time") < starttime_of_standard_alerting OR hour("time") >= endtime_of_standard_alerting)))
