Kapacitor v. 1.5
Theres a long day and alot of code that has brought me to this point. I am trying to get alerts for a large series of metrics and have created a test tickscript to discover how this may be accomplished.
Goal: if a metric has a value of 0 for 5 minutes, send an alert for that metric. Edit: Also, if no points are sent for those 5 minutes send the same deadman alert. The following tickscript code provides this without the time, instead immediately reporting a value of 0 when it occurs.
Note: I have tried using deadman(threshold, time) method. This fails every time because for some reason it doesn’t report for a 0 value, it only reports when the metric no longer updates to influxDB.
I have also tried creating my own deadman with several combinations of stats() and derivative() with and without each other.
I have tried using chronograf generated deadman and threshold. Threshold doesn’t provide time, deadman doesn’t actually work for a attrValue of 0 which is being submitted as a field as a double and I have tried casting it as such into a deadman node to be safe.
My question, what needs to be added to the script below to discover the value being 0 for 5 minutes and trigger alert only then?
var db = ‘streamDB’
var rp = ‘retention’
var measurement = ‘measurement’
var groupBy = [‘host’, ‘topic’]
var whereFilter = lambda: (“topic” == ‘test_test’)
var name = ‘stest’
var idVar = name + ‘-{{.Group}}’
var message = '{{.ID}} {{.Level}} @ {{.Time}} for {{.Tags}} {{.Fields}} ’
var idTag = ‘alertID’
var levelTag = ‘level’
var messageField = ‘message’
var durationField = ‘duration’
var outputDB = ‘chronograf’
var outputRP = ‘autogen’
var outputMeasurement = ‘alerts’
var triggerType = ‘threshold’
var crit = 0
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: “attrValue”)
.as(‘value’)var trigger = data
|alert()
.crit(lambda: “value” <= crit)
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
.stateChangesOnly()
.slack()
.channel(‘#channel’)trigger
|eval(lambda: float(“value”))
.as(‘value’)
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag(‘alertName’, name)
.tag(‘triggerType’, triggerType)trigger
|httpOut(‘output’)
Showing the task:
DOT:
digraph chronograf-v1-0adab7bf-a05f-483b-8936-9115c5e4ca61 {
stream0 → from1;
from1 → eval2;
eval2 → http_out3;
http_out3 → derivative4;
derivative4 → http_out5;
http_out5 → alert6;
alert6 → eval7;
alert6 → http_out9;
eval7 → influxdb_out8;
