I’ve written following TICK script which should alert if UPS External Temperature goes below or above threshold.
The script doesn’t produce any errors and I’ve verified that the measurement contains data.
What I’m doing wrong here?
Kapacitor OSS 1.5.3 (git: HEAD e6bc51b8447de450c3f6fc0f6e47b6a0987ce5b6)
> SELECT external.temperature FROM ups WHERE hostname='ups2' AND time > now() - 120s
time external.temperature
1571401760000000000 5
1571401770000000000 5
1571401780000000000 5
1571401790000000000 5
1571401800000000000 5
1571401810000000000 5
1571401820000000000 5
1571401830000000000 5
1571401840000000000 5
1571401850000000000 5
1571401860000000000 5
dbrp "telegraf"."autogen"
// Select ups external temperature
stream
|from()
.measurement('ups')
.groupBy('hostname')
|eval(lambda: "external.temperature" / 10)
.as('temperature')
|stateDuration(lambda: "temperature" < 8)
.unit(1m)
.as('warnDuration')
|stateDuration(lambda: "temperature" < 4)
.unit(1m)
.as('critDuration')
|stateDuration(lambda: "temperature" > 30)
.unit(1m)
.as('warnDuration')
|stateDuration(lambda: "temperature" > 35)
.unit(1m)
.as('critDuration')
|alert()
.pagerDuty2()
.routingKey('xxxxxxx')
.link('https://graphs.jus.si/d/000000001/ups?orgId=1&refresh=10s&fullscreen&panelId=11&from=now-1h&to=now', 'UPS Dashboard')
.warn(lambda: "warnDuration" > 1)
.crit(lambda: "critDuration" > 1)
.stateChangesOnly()
.message('{{ .Level }}: UPS {{ index .Tags "hostname" }} external temperature is {{ index .Fields "temperature" }}°C')
DOT:
digraph ups_external_temperature_alert {
graph [throughput="0.00 points/s"];
stream0 [avg_exec_time_ns="0s" errors="0" working_cardinality="0" ];
stream0 -> from1 [processed="20"];
from1 [avg_exec_time_ns="1.345µs" errors="0" working_cardinality="0" ];
from1 -> eval2 [processed="20"];
eval2 [avg_exec_time_ns="0s" errors="0" working_cardinality="2" ];
eval2 -> state_duration3 [processed="20"];
state_duration3 [avg_exec_time_ns="8.776µs" errors="0" working_cardinality="2" ];
state_duration3 -> state_duration4 [processed="20"];
state_duration4 [avg_exec_time_ns="2.167µs" errors="0" working_cardinality="2" ];
state_duration4 -> state_duration5 [processed="20"];
state_duration5 [avg_exec_time_ns="5.781µs" errors="0" working_cardinality="2" ];
state_duration5 -> state_duration6 [processed="20"];
state_duration6 [avg_exec_time_ns="5.47µs" errors="0" working_cardinality="2" ];
state_duration6 -> alert7 [processed="20"];
alert7 [alerts_inhibited="0" alerts_triggered="0" avg_exec_time_ns="0s" crits_triggered="0" errors="0" infos_triggered="0" oks_triggered="0" warns_triggered="0" working_cardinality="2" ];
Level: OK
Collected: 0
Handlers: []
Events:
Event Level Message Date
