Hey everyone,
I created the following TICKScript based on the autogenerated on using Chronograf:
stream
|from()
.database('telegraf')
.retentionPolicy('autogen')
.measurement('ardu_terra_hot_side')
|eval(lambda: "value")
.as('value')
|alert()
.crit(lambda: "value" > 10)
.message('{{index .Tags "who"}}s Terrarium ist zu kalt ({{index .Fields "value"}} °C). Arduino möglicherweise defekt!')
.id('Too hot')
.idTag('alertID')
.levelTag('level')
.messageField('message')
.durationField('duration')
.stateChangesOnly()
.email()
.to('xxx@xxxx')
.telegram()
.chatId('xxxx')
.parseMode('Markdown')
Sadly the script doesn’t alert when the value is above the threshold.
Can someone help me?
Greetings
Knerd
