Hi there I have the following very simple tick script
# kapacitor show pg_max_connection
Error:
Template:
Type: stream
Status: enabled
Executing: true
Created: 19 Jun 20 13:59 UTC
Modified: 19 Jun 20 14:03 UTC
LastEnabled: 19 Jun 20 14:03 UTC
Databases Retention Policies: [“pgstats”.“autogen”]
TICKscript:
dbrp “pgstats”.“autogen”
var data = stream
|from()
.measurement('pgstats_databases')
.groupBy('cluster', 'account')
data
|alert()
// critique a 95%
.crit(lambda: float("percent_connection_usage") > 25.0)
// formatage du message
.message('[Kapacitor Alert] {{ index .Tags "cluster" }} , {{ index .Tags "account" }}: Connexion usage is {{ index .Tags "`percent_connection_usage`" }}')
.email()
DOT:
digraph pg_max_connection {
graph [throughput="1.00 points/s"];
stream0 [avg_exec_time_ns="0s" errors="0" working_cardinality="0" ];
stream0 -> from1 [processed="1012503"];
from1 [avg_exec_time_ns="7.681µs" errors="0" working_cardinality="0" ];
from1 -> alert2 [processed="1012503"];
alert2 [alerts_inhibited="0" alerts_triggered="0" avg_exec_time_ns="27.564µs" crits_triggered="0" errors="0" infos_triggered="0" oks_triggered="0" warns_triggered="0" working_cardinality="17" ];
When I look at my grafana, I have a bunch of “percent_connection_usage” that are aboce 25 and , the alert doesn’t fire.
What am I missing ? what is wrong with the way I’ve written my alert ? Is there a way to debug this ?
Ludo
