I have a TICK Script to retrieve a field - queue depth of an MQ queue from Influx DB and compare the value with another field - alert threshold also in InfluxDB.
My requirement is if the queue depth is greater than alert threshold then send an alert to an email.
below is a sample of my tick code:
var inCount = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: "input_count")
.as('value')
|log()
var curDepth = stream
|from()
.database(db)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: "current_q_depth")
.as('value')
|log()
var data = inCount
|join(curDepth)
.as('inCount', 'curDepth')
var trigger = data
|alert()
.crit(lambda: "curDepth.value" > "inCount.value")
.stateChangesOnly()
.message(message)
.id(idVar)
.idTag(idTag)
.levelTag(levelTag)
.messageField(messageField)
.durationField(durationField)
trigger
|eval(lambda: float("value"))
.as('value')
.keep()
|influxDBOut()
.create()
.database(outputDB)
.retentionPolicy(outputRP)
.tag('alertName', name)
trigger
|httpOut('output')
As soon as I save this script, it magically gets removed from the Alert Rules and I get an evaluation error in the logs.
Upon debugging, I figured this script give me error at line:
|alert()
For the Alert above, if I change the code to
var crit = 10
|alert()
.crit(lambda: "value" > crit)
This code works and the Alert rule works just fine, sending an email alert.
Now, Can I not do a comparison with dynamic values for alert node? Could you pls. suggest what am I missing or is this feature not supported in TICK Script?
Thanks,
Rav
