Afternoon,
Hopefully this isn’t too out of place, but I’m going stir crazy here. I’m sure this was working fine, but now it isn’t…
I have the following TICKscript:
// Measurement selection
var db = 'telegraf'
var rp = 'autogen'
var measurement = 'winperf_hypervhealth'
var groupBy = ['host']
var whereFilter = lambda: TRUE
// Get a window of data
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
// Keep only one field
|eval(lambda: "Health_OK" + "Health_Critical")
.as('Total_VMs')
.keep()
|influxDBOut()
.database(db)
.tag('kapacitor', 'true')
There are 4 nodes sending the winperf_hypervhealth metric to InfluxDB and I’ve confirmed that they have all submitted values with the following query:
SELECT last("Health_OK") AS "last_Health_OK" FROM "telegraf"."autogen"."winperf_hypervhealth" WHERE time > now() - 5m GROUP BY time(10s), "host" FILL(null)
However, when I check my new field of Total_VMs, I only see the calculated value from one of the nodes. If I alter my TICKScript to log with the alert() node, I can only see that same node’s entries.
Any ideas? Did I fudge up my TICK script?
Cheers.
